Thrown Rod on 383 Stroker
Old May 11, 2010 | 10:52 PM
  #81
71_S-Ray's Avatar
71_S-Ray
I'm currently dealing with a flat cam / stuck valve issue. All my pushrods were intact however many of them were loose with 2 extremely loose. One day my engine is running stronger than it has ever done so before and the very next I'm just cruising the freeway at65 and it starts popping up a storm.
The only thing that could possibly make sense to me about this is the camshaft literally disintegrated. You need to do a full tear down I would say. And I would definitely have some choice words for that builder.
Good Luck!
Old May 11, 2010 | 11:01 PM
  #82
TimAT's Avatar
TimAT
I lost a cam in a BB once. Broke between the 3 and 4 bearings- Piece dropped on the crank at about 1500 RPM. Saved the rocker covers and the intake. It even broke the water pump.
Old May 12, 2010 | 10:59 AM
  #83
75+78 Corvettes's Avatar
75+78 Corvettes
Ouch. like everyone says, probably the cam is in multiple pieces. Hopefully your builder will treat you right, otherwise, I'd get a crate engine.
Good luck!
Old May 12, 2010 | 12:12 PM
  #84
pauldana's Avatar
pauldana
again.... wow.... would have never thought..... wow......p
Old May 12, 2010 | 12:29 PM
  #85
kapla74's Avatar
kapla74
don´t let this die..pls I want to know how this ends up...
Old May 12, 2010 | 12:44 PM
  #86
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Yeah I wanna see the inside of the motor and what's in the pan
Old May 12, 2010 | 12:52 PM
  #87
Lt1er's Avatar
Lt1er
Originally Posted by Lt1er
the engine just backfired and died
Like other said i would pull both valve covers and see what is amiss
What if the cam broke away between two journals. That could drop lifters and pushrods down in the pan and kick one out the side.
Do I win a prize or is that the problem not for sure yet?
Old May 12, 2010 | 01:12 PM
  #88
MotorHead's Avatar
MotorHead
You haven't won yet, I am still in the running The winner of the first prize for the correct guess, a banana sandwich, will have to wait until the pan is off
Old May 12, 2010 | 03:47 PM
  #89
Tumarr's Avatar
Tumarr
Originally Posted by Tumarr
I think your cam broke into pieces and you got a lifter in your pan.
not so fast LT1er I said it in post 47, thats my banana sandwich dang it! LOL
As a dedicated drag racer, you get to see all kinds of wonderful engine carnage at the drag strips.
Old May 12, 2010 | 04:04 PM
  #90
Tumarr's Avatar
Tumarr
If it was a cam shaft failure that caused this disaster, I would not be so quick to jump on the engine builder for the blame. I would send the blame towards the cam manufacturer. There are alot of inferior metal castings floating around these days due to lower quality controls and imported metals. My buddy who owns a machine shop here was telling me a story how he was in the middle of balancing a high quality forged crank. he was drilling out one of the counter weights when the drill's metal shavings suddenly started looking funny. he studied it for a second and figured out he drilled into a peice of charred wood. some must of gotten into the molten metal or it wasnt fully purified at the forged but sure enough there was wood in side a $2000 dollar crank shaft.
Old May 12, 2010 | 04:21 PM
  #91
Lester B's Avatar
Lester B
Not looking good..... I am guessing at this point but thinking that the cam shaft has broken and the centre section that drives cylinders 3, 4, 5 and 6 has broken away and thats what allowed the push rods to drop?
Did you have the engine built for you? The question that is crossing my mind is who clearanced the block for the 383 and who chose the rods, bolts and cam, also who set it up? I looked very closely at building a 383 prior to my previous build. I am almost sure that there is potential rod/rod bolt to cam clearance issues if the correct components arent used. Is it possible that a rod bolt hit the cam and broke the cam causing the failure we see here?
Your next step all depends on your knowledge/budget and previous build situation. Do you have any come back on the engine build or is it a case of your on your own and on a limited budget?
Feel real sorry for you, I had a bottom end failure on my SB at the start of last year, real heart sinking. It can be sorted though, be prepaired to be on a fairly steep learning curve.
Lester
Old May 12, 2010 | 04:26 PM
  #92
LFZ's Avatar
LFZ
me too
Old May 12, 2010 | 05:21 PM
  #93
...Roger...'s Avatar
...Roger...
Is it possible that was done on purpose ?
Someone told me the C5s have balsa wood floors.
Old May 12, 2010 | 05:25 PM
  #94
Belgian1979vette's Avatar
Belgian1979vette
Ok, i assume that the cam is gone. But i'm still quite impressed that the rod is practically undamaged after all it went through.
Let us see the underside of the motor and what is in de oilpan.
Old May 12, 2010 | 06:44 PM
  #95
Lt1er's Avatar
Lt1er
Not soon enough for you either post #31 & 32 forvicjr
I personnally have never seen a broken cam in the shaft part. I have seen broken off dist. gear teeth and the bolts to the cam sproket sheared off
Old May 12, 2010 | 07:00 PM
  #96
...Roger...
I had a 71 LT1 throw 2 rods and over half the cam shaft was in the pan. What a mess !!!
Old May 12, 2010 | 07:05 PM
  #97
Tumarr's Avatar
Tumarr
At my buddies shop, hes has a shelf of all sorts of interesting broken peices. one thing is a piston with part of a camshaft perfectly imbedded into the crown of a piston. this happened a small block ford heavy nitrous motor. two rods broke and all sorts of hell broke loose inside the motor.
To Thrown Rod on 383 Stroker
Old May 14, 2010 | 12:12 AM
  #98
babbah's Avatar
babbah
Old May 19, 2010 | 05:23 PM
  #99
kapla74's Avatar
kapla74
any updates here???
I need to know..pls...
mystery is killing me.
Old May 19, 2010 | 06:45 PM
  #100
MotorHead's Avatar
MotorHead
