Two brackets
Old May 13, 2010 | 08:38 PM
bugzbunny's Avatar
bugzbunny
Default Two brackets
Could anyone tell me what the 2 brackets in the back interior (one on each side) are for. They have holes as if a bar of some kind goes there?
Old May 13, 2010 | 09:09 PM
Peterbuilt's Avatar
Peterbuilt
They might be for the straps to hook onto but you need a third one near the front.
Old May 13, 2010 | 09:47 PM
76yellow's Avatar
76yellow
What year, coupe or convertible & where in the back ?
Old May 13, 2010 | 10:30 PM
bugzbunny's Avatar
bugzbunny
coupe 69 against the back fiberglass
Old May 13, 2010 | 10:31 PM
bugzbunny's Avatar
bugzbunny
strap for what?
Old May 13, 2010 | 10:34 PM
Peterbuilt's Avatar
Peterbuilt
To hold the "T" tops in place.
Old May 13, 2010 | 11:28 PM
gbvette62's Avatar
gbvette62
If your referring to the 2 nickle plated metal loops, that are each held down by 2 phillips head screws, then they are for the rear luggage hold down "Y" strap.
All 68-82 Corvettes came with these straps. They were made of color keyed webbing similar to seat belt material, but only about an inch wide. Originally there would have been a third, identical loop just above the park brake console, attached to the bulkhead that's behind the seats. The strap had 3 hooks and would attach to the 3 loops. There's a buckle in the center to adjust the tension of the belt.
Old May 13, 2010 | 11:47 PM
7T1vette's Avatar
7T1vette
If not the loops for the straps, they could be the hinges for the rear window stowage tray. Do you have one?
Old May 15, 2010 | 09:41 AM
bugzbunny's Avatar
bugzbunny
No I don't have the tray . Thanks for all the info I was just curious. I put speakers back there so I can't use them anyways.
To Two brackets
