front end shake
Old May 21, 2010 | 12:11 PM
steve dalla's Avatar
steve dalla
Default front end shake
hello all, i have an 1980 vette that has developed a SERIOUS shake when cruising down the road at about 40 mph. It feels like the car is about to rattle apart. I noticed that if i get on the throttle real hard the shake goes away,leading me to suspect problem in front end. Also it cruises fine at about 75-80. are there any things i can look at in the garage before i take it in? im new to front end suspension work but have decent knowledge about cars. thanks all!!!
Old May 21, 2010 | 12:15 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
First step is to eliminate tires from the equation. Check them for sep and if you don't know how to check seperation, just drive to a tire shop and have them take a look at them. Tread sep is easily visible to a tire person (I ran tire shops 20 years) but the average mechanic does not know what to look for.
Old May 21, 2010 | 12:54 PM
OregonVette80's Avatar
OregonVette80
yep yep yep... I would be willing to bet the farm that these are old tires that may have come with your car? Save yourself a ton of headache & just take them in for balancing & rotating.
Old May 21, 2010 | 01:05 PM
7T1vette's Avatar
7T1vette
If they are more than 10 years old, replace them...before you have a blowout at speed and badly damage the car or yourself.
Old May 21, 2010 | 11:01 PM
steve dalla
6 month old M/T and pro star wheels that were balanced and installed. already retorqued wheels as well . what else????
Old May 21, 2010 | 11:14 PM
Attfay Elleybay's Avatar
Attfay Elleybay
Ball joints? Jack up a tire and see if you can move it side to side.
Old May 22, 2010 | 12:39 AM
Goody's Avatar
Goody
Jack up front as suggested and grab the wheel at the 3 and 9 o'clock positions and try to turn the wheel by hand. Also while still in the air also put a large prybar or a jack under the wheel and see if it moves vertically at all, report back with any play.
Old May 22, 2010 | 10:36 AM
SanDiegoPaul
That does not mean you don't have a tire that has seperated. It happens to brand new ones!
And M/T can suffer from it too, it's something that happens to all tire companies including Goodyear, Bridgestone, and Firestone.
Are the tires on the car radials?
Old May 22, 2010 | 10:37 AM
SanDiegoPaul
That won't cause a vibration. Tire wear and wander yes but not vibes.
Old May 22, 2010 | 06:32 PM
steve dalla
tires front and back are bias ply
Old May 22, 2010 | 08:58 PM
mad pad house's Avatar
mad pad house
A few years back my 71 had much the same problem I thought the front end was goig to fall off.Turned out one of the U joints on the drive shaft had gone bad,But I would still look at the tires.
To front end shake
