Engine hoist
Old Aug 8, 2010 | 05:58 PM
billsfan's Avatar
billsfan
Default Engine hoist
I'm looking to buy an engine hoist for my '76. Do I need a 2-ton hoist, or will a 1-ton hoist work? None of the vendors list the clear reach from their hoist, they only seem to care about the total lift. I know I need at least 36" reach to clear the fender with the jack cylinder.
Old Aug 8, 2010 | 06:49 PM
BigBen69's Avatar
BigBen69
A 1 ton is enough, if it has a long enough reach.You will have to come from the side,instead of the front,vettes arent like most cars when it comes to pulling the engine.
Ben
Old Aug 8, 2010 | 06:54 PM
nomocrap's Avatar
nomocrap
I bought my engine hoist from Harbor Freight it is a 1 ton it folds for storage. I have pulled many engines with mine it works great. The lasest flyer from Harbor Freight has it for $139.99 spend extra for their motor leveler JAY
Old Aug 8, 2010 | 07:02 PM
mrvette's Avatar
mrvette
IMO, try dublicating my experience here, buy a older minimum 5' boom length KD hoist from a rental place....
I paid 150 bux for mine, best damn investment I ever made....
Old Aug 8, 2010 | 07:32 PM
L88Plus's Avatar
L88Plus
I snagged a pair from Harbor Freight (China Trading Co.) that have swivels on the hooks. I love 'em, the straight chain and hook setup wants to straighten itself out to whatever angle it wants which is rarely what I want. The swivels allow me to position the engine exactly where I want it and let go without unwinding the chain.
Old Aug 8, 2010 | 08:19 PM
oleyellar72's Avatar
oleyellar72
Default hoist
imho get the 2ton while a 1ton will do and is cheeper the extra tonage make things easier and you never know what you need to lift down the road...
Old Aug 8, 2010 | 10:16 PM
snoopykissedlucy's Avatar
snoopykissedlucy
I fully agree and own both 1 ton and a 2 ton:
A one ton works..........but please note on this picture, when you extend the length of the boom outward, the weight limit decreases.
Note the silver pin that can be inserted at different lengths along the boom.
Also, chances are that you are only going to lift and insert the motor only instead of the motor/tranny combo........which is definately less than 1 ton.
Old Aug 8, 2010 | 10:37 PM
Solid LT1's Avatar
Solid LT1
I have used a 1ton for many projects but, I just went to Harbor Freight and bought a 1ton chain hoist for my recent install. When my buddy who has my engine hoist called and said I run it back over to you, I said, no it's like the game of tag and your "IT!" I'll call you when I have room in my garage to store it again until then KEEP IT!
Old Aug 8, 2010 | 10:58 PM
John 65's Avatar
John 65
I like the 2 ton better being that you can have the longer reach with it and pull the motor from the front of the car.
Old Aug 8, 2010 | 11:02 PM
7T1vette's Avatar
7T1vette
Well, the engine weighs less than 1/2 ton....BUT, each of those portable hoists has an extendable boom on it. Depending on how far you extend it, the boom capacity changes. With a 1 ton hoist, it will lift up to 1 ton on the inner-most boom position. That amount of extension will not allow you to reach the center of the engine compartment.
So, you will need a 2 ton capacity hoist to get the job cone SAFELY. Will a 1 ton hoist do the job...maybe, maybe not.
Old Aug 9, 2010 | 07:04 AM
99 Black Bird TA's Avatar
99 Black Bird TA
As long as your working with small block chevy, LS1 engines or similar the 1 ton should be fine.
We've used 1 ton's fully extended to the 1/2 ton mark to move a 455 Pontiac all cast iron w/accessories attached. The hoist did ok. However, a 750 pound rated engine stand started bending when most of the 455's weight was on it. I think it would have broke the 750 pound stand. If I was working a lot with the big motors I'd probably want the 2 ton hoist.
Old Aug 9, 2010 | 07:42 AM
L88Plus's Avatar
L88Plus
You may be amazed at what you can do with a shop crane/engine hoist. I helped a buddy lift the rear of a K-5 Blazer to sling a new rearend under it this weekend. The 2-ton China Trading Co. piece worked great! Get the big one, you never know what you might find to use it for.
To Engine hoist
