Automatic Transmission issues
A. The automatic transmission
Q. Should a novice attempt to work on a TH400
A. Sure why not, what could go wrong?
Ok here's the deal, my 68 TH400 wouldn't kickdown, otherwise working great. Messed around with the switch on the gas pedal, no luck.
Hooked up a remote switch to the leads on the gas pedal switch and lifted the car.
When I throw the switch I get 12 volts to the kickdown terminal on the tranny, but no "click".
So I ordered a new Kickdown solenoid online and tonight pulled the tranny pan. Pulled out the old solenoid. It looks different. More on that below. I tested it out of the tranny and it now "clicks" and actuates. Maybe an intermittent problem.
Question 1.
If the kickdown solenoid is working, what else could be the problem?
Question 2.
Look at these two kickdown solenoids. The new one is on the right. It looks less robust. The old one has a round disc with a tiny hole that a tapered needle/pin centers in. There is also a shim that you can see next to it. The new one has a litte circular "screen" instead of the pin/disk.
I think I'll go ahead and put in the new solenoid.
Should I put the shim in with the new solenoid or leave it out?
Is the new solenoid correct despite it's different design?
(ok that was 2 questions)
Question 3.
The pick up filter has a tube with two O rings. I just kinda pulled it down to remove it. One O ring is still in the bore, the other is on the tube. Should I just shove it back in?
Question 4.
While looking over the tranny, I found this connection "nipple" on the right side, top of the case with nothing attached to it. What is this? What should be attached?
Any help appreciated!
Fred
What would be the fix?
