Qjet reinstall
Old Sep 3, 2010 | 09:49 PM
BBCorv70's Avatar
BBCorv70
Default Qjet reinstall
Anybody know what to torque the mounting bolts/nuts on a QJet?
Don't want a vacuum leak or warped base....
70 LS5
Old Sep 3, 2010 | 10:00 PM
mudbone64's Avatar
mudbone64
From: I'd like to propose a toast... to internal combustion and wind in the face.
I'd say my personal torque value is firm/snug. Honestly, I don't believe it's all that critical. Considering the material the carb is made of I don't think you'd want to get them too tight. There's no need to break out the 1/2" drive sockets when a 1/4" or a 3/8" drive will do just fine. Just snug'em up and they'll be fine.
Old Sep 3, 2010 | 11:39 PM
7T1vette's Avatar
7T1vette
8-10 ft-lbs.
Old Sep 4, 2010 | 07:57 AM
mudbone64's Avatar
mudbone64
Remember to get your metal fuel line started before you start installing the mounting bolts. Also, tighten the bolts evenly in a criss-cross pattern. I don't know your experience level so I thought I'd just pass this on.
Old Sep 4, 2010 | 09:02 AM
Alan 71's Avatar
Alan 71
Hi BB,
I found this in the 71 AIM.
"Torque left/front and right/rear to 24-48 in.lbs., then right/front and left/rear to 24-48 in.lbs. THEN go through the same sequence at 120-168 in.lbs torque.
I'm not sure how in.lbs. translates to ft.lbs.? Does it end up at 7T1's numbers?
Regards,
Alan
Old Sep 4, 2010 | 09:46 AM
7T1vette's Avatar
7T1vette
120-168 in-lbs is equivalent to 10-13 ft-lbs. Since you change the scale from inches to feet, it is reduced by a factor of 12.
My "8-10 ft-lbs" was from memory. Alan's info was directly from the AIM, and it also includes specifics about 'how' to torque those bolts. Use Alan's data.
Old Sep 4, 2010 | 11:40 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
10-13 ft/lbs sounds like a lot.
Try this. Using a 1/2" socket (no ratchet yet) run the bolts as far as you can by hand. Then add another 1/4 turn with a ratchet.
That's plenty.
Old Sep 5, 2010 | 12:02 AM
PRNDL's Avatar
PRNDL
Someone on this forum gave me the secret formula: Tighten the bolts just until they strip, then back off 1/2 turn.
Old Sep 5, 2010 | 12:30 AM
rcread's Avatar
rcread
I know Cliff of Cliff's QJets sometimes just sets the carb on the intake (over studs) without using nuts and tests them that way. The vacuum is enough to hold the carb on when the car isn't moving, so you want minimal torque.
Old Sep 5, 2010 | 02:35 AM
BBCorv70's Avatar
BBCorv70
Originally Posted by Alan 71
Hi BB,
Regards,
Alan
Hi Allan,
Thanks. I may need to purchase a torque wrench which reads inch pounds. I could probably go by feel but over the years I've been paying closer attention to torque values specified to remove any doubt.
Old Sep 5, 2010 | 02:36 AM
BBCorv70's Avatar
BBCorv70
Thanks all for your input. Appreciated.
Old Sep 5, 2010 | 07:45 AM
Alan 71's Avatar
Alan 71
Hi 7T1,
Thanks for the info.
It shows I can read and make it look pretty but don't know much about the technical part of it.
Regards,
Alan
Old Sep 5, 2010 | 08:15 AM
mar's Avatar
mar
They say even Tq all the way around is critical to prevent binding in the butterfly shafts???
Old Sep 5, 2010 | 03:42 PM
lars's Avatar
lars
Here's a safe way to do it without risking any damage to the carb or procuring an in/lb torque wrench. Keep in mind that very little torque is needed to secure the carb:
Use a 3/8" drive ratchet with a deep 1/2" socket. Grab the ratchet by its head, wrapping your hand around the head of the ratchet only - don't grip the handle. Snug the bolts down with the torque you can get just holding onto the ratchet head. This will be just enough to slightly compress the base gasket, but will not distort the carb castings in any way.
I will often test my rebuilt carbs the same way Cliff does: I just drop them onto the intake on studs and let the carb sit loose: Engine vacuum will pull the carb down and seal it. If it doesn't, it identifies a warped carb baseplate, and I use this as a troubleshooting method.
Lars\
To Qjet reinstall
