Anyone ever use an Engine Test Stand?
Old Sep 4, 2010 | 03:37 AM
snoopykissedlucy's Avatar
snoopykissedlucy
Default Anyone ever use an Engine Test Stand?
Anyone ever use an Engine Test Stand to break-in an engine? Or tune an engine?
Any suggestions as to welding one VS buying one? The cheapest I found was $500 but I'm tempted to make one but I dont have a welder.
Old Sep 4, 2010 | 09:10 AM
73BLWN's Avatar
73BLWN
Yep. I built this one 20 some years ago.
I've had Fords, Olds, and countless chevy engines started and broke in on it. I like using one because you can check for leaks, adjust valves, play with the carb, and do compresson checks prior to dropping it in the vehicle. Mine is set up for the engine and transmission. I usually drop the engine and tranny in together, so it has worked well for me. It's nothing fancy but it has served me well.
Old Sep 4, 2010 | 02:59 PM
snoopykissedlucy
Whoa, very nice! What size square tubing did you use?
I see the triangulation for the engine mount bars but did you just drill a hole in the tubing for the mount bolt?
Old Sep 4, 2010 | 03:17 PM
Billysvette's Avatar
Billysvette
I have and still do use a regular engine stand and i run water hose to it to keep cool ,regulate it also,i have supports that run up from bottom square bar ,that has the rollers on it,to the engine mounts.Works great and super cheap I might have $100.00 in it.Then you run wires to the starter with a start button,to the battery that sits on floor and another wire to + distributor.Ive seen alot of guys on here that do it also.
Old Sep 4, 2010 | 03:39 PM
snoopykissedlucy
Whoa, so weld some tubes from the motor mount down to the front tires area?
I'm worried that the whole thing will flip on its side due to rotational forces.....am I just overthinking it?
Also, the water hose thing sounds good but what do you do with the upper hose? Let it empty into a bucket?
Have any pics?
Old Sep 4, 2010 | 04:47 PM
Billysvette
Dont have any pics ,but some body on here does,they have posted it before.If you are not knowegable about the working of the engine and how to do this,i would not do it.It is simple though to do if your mechanically incline.I drilled a hole through the bottom of the engine stand and i ran flat bar from there to the motor mounts and welded 3/8 pipe ,about 3 inches long on top of flat bar and i bolted motor mounts on engine and ran a bolt through to hold engine still.Does that sound understandable? The flat bar does have to be bent and angled up to the motor mounts. Where i drilled holes in the stand ,i ran a bolt through there and a lock nut ,and the flat bar will pivot now and when there isnt a engine on stand you can push them down towards the floor and out of the way ,if you wanted.
Old Sep 4, 2010 | 06:13 PM
7T1vette's Avatar
7T1vette
Since you don't have any way to 'load' the engine on one of those stands, you can't really generate much engine torque to make it 'roll'. If you did something stupid, maybe....but why would you do that? An un-loaded test stand is for checking out leaks, carburetion, ignition and timing. You need a dyno hooked to it to do anything else.
Old Sep 4, 2010 | 09:51 PM
Artsvette73's Avatar
Artsvette73
Made my own
Old Sep 5, 2010 | 12:19 AM
cboyd's Avatar
cboyd
We used one to break in the cam. Some people have not much use for them, but I usually run the cam in, check for leaks and such.
C
Old Sep 5, 2010 | 02:03 AM
Solid LT1's Avatar
Solid LT1
I used one to break in my 70 LT-1 motor and keep an eye on lifter patterns while breaking in the flat tappet cam. Worked well and kept my paint job on the Vette in excellent condition. Make sure if you run a total loss water system (from the faucet) to restrict the outflow a little bit to build system pressure in the cooling system.
Old Sep 5, 2010 | 09:48 AM
73BLWN's Avatar
73BLWN
It's just 1" square tubing. It was probably one of the first projects, I made with my wirefeed welder. I used fluxcore wire. Most of the welds are embarrassing to look at. I overthought the rotational twisting, and had a large beam clamped to the frame with sand bags weighing it down. After I fired it up, I realized duh, the motor is just spinning, it can't transfer the load unless the flywheel is hoked up to something. It shakes a bit because of the lopy cam, but it's never came apart.
Yep, I drilled one single hole through the square tube to allow the motor and tranny to move forward and backwards so different tranny's could be mounted.
That picture doesn't show the radiator mount very well. It actually has two vertical posts that sandwich the radiator. The c-clamps towards the bottom allow you to slide the radiator forward and backwards.
Can't imagine I have more the $75 or so into it. I bought a cheap-o trio gauge set for monitoring the motor vitals.
Having more experience and money, I'd like to build a more refined version, but there is really nothing so wrong with my rookie first attempt, why bother.
So, I say, go get some steel, and cut and weld away.
Old Sep 5, 2010 | 10:14 AM
1976 corvette's Avatar
1976 corvette
73BLWN, is there a reason or benefit to having the tran hooked up or did you just do that to make sure everything ran in perfect harmony before installing?
Old Sep 5, 2010 | 12:03 PM
73BLWN's Avatar
73BLWN
I guess I like it all on one stand because I can store it like that until I'm ready to drop it in. I use to drop them both in the engine bay at the same time. Now I have a removeable tranny crossmember, so it's easy enough to install the motor without the tranny.
Oh, now I remember one reason. I didn't like the flywheel dangerously exposed, spinning around on the back of the motor waiting to grab cloths, wires, or flesh.
Old Sep 5, 2010 | 12:08 PM
1976 corvette
Good call. With an engine like that it could really do some damage.
Old Sep 5, 2010 | 06:36 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I use one every chance I can. Fire it up, break in flat tappet cam, ck for leaks, retorque heads etc etc.
Here's a recent 400" disguised to look like a 283/270 being run.
A 555" last year...
Another 555" this year...
This stand belongs to our Vette group and is rotated constantly among everyone. Seems like there is always something being fired up on it from Chevy's to Pontiacs and even Fords on it. You can see the protective cardboard on the corners to protect it during all the pickup rides it takes!
A steady agreement is that everyone needs to try and add an improvement to it each time they use it. It's getting pretty nice!
A buddy built one for me last year for a Christmas present. I just need to finish adding all the goodies to it...but it's going to be even better!
It takes very little to hold it in place. They don't move around at all when running or revved.
JIM
Old Sep 5, 2010 | 11:16 PM
Ray Y's Avatar
Ray Y
I used one that belongs to a buddy of mine earlier this year when I built my 555. It's a lot easier to fix anything should you need to in the stand than in the car. You can set the timing with the cast iron manifolds and then easily swap to the headers if you concerned about burning off coatings, etc.. Plus, it's just cool to be able to walk around it while it's running and see it from every aspect.
....and you've got to watch the video to really appreciate it:
http://www.youtube.com/watch?v=MVfocgqrHts
Old Sep 6, 2010 | 10:05 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Finished mine last week and ran the engine for a while on it. Given how much a PITA it is to do some types of engine work while it's in the car, I always run mine on a stand first. I sold my original stand a couple years back, and the guy apparently likes it too much to sell it back to me after I inquired about getting it back to run the new engine. A picture during the build of the new stand:
Running the engine last week:
Fortunately no problems, but I always feel better if I can get good access to the engine in the event of having to make a repair or correction to the engine.
To Anyone ever use an Engine Test Stand?
Old Sep 6, 2010 | 11:43 PM
Ironcross's Avatar
Ironcross
I`ve always used my rolling rubber tired engine stands to check out my engines for whatever needs was necessary...here's one of them.....
Old Sep 7, 2010 | 12:04 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Walt, you always make me impressed with what you have!
Old Sep 7, 2010 | 12:39 PM
lars's Avatar
lars
I've been using a run stand for every engine I've built for the past 5 years. I hang the engines from a bellhousing, and the stand is drilled to accept various bellhousing tranny bolt patterns. I have an inventory of various bellhousings to bolt onto the stand, so I can install almost any engine in under 30 minutes. I have my "standard test engine" bolted to the stand most of the time, and I use this to test all the carbs I rebuild.
A run stand is good for breaking in cams, checking for leaks, setting timing, adjusting the carb, and overall setup, but you cannot break in rings on a no-load test stand: You have to put the engine under load to seat the rings. For this reason, you want to be a little careful about how long you run a new engine under no load on a run stand: Set the engine up, let the cam break in, and fix your leaks. Then, get the engine in the car and get it under a hard load to make sure the rings seat.
Some photos of my well-used run stand:
This last one is an early photo when I first built the stand: I thought I needed members coming up and supporting the engine at the engine mounts. This turned out to be unneccessary, so the current version of the stand uses nothing but the bellhousing to hang the engine off:
