427cu or 540cu......
Old Oct 17, 2010 | 11:03 PM
richiev88's Avatar
richiev88
Default 427cu or 540cu......
I have be kitting up to replace the small block in my 69 with 427. I believe the car to be a factory 435hp car. I have early alloy heads and few other parts sorted.
A good Mate is a big block nut, he thinks I am mad to spend all this money on a 427........ as visually will be hard to tell the difference.
Now a reasonably priced 540cu has become available, with would cost me about the same as the 427 to build, but with new heads RHS ( I read that the old alloy GM castings are prone to cracking )
I like the idea of 600hp plus on pump gas, new generation heads ect, but am scared about busting up the drivetrain, gas economy ( if you can use 540 and gas economy in the same sentence).
The other part of me is saying 427 on BFG's will be plenty of hp, gas economy will be some what better, and the car in an origional configuration......
Thoughts
Old Oct 18, 2010 | 12:06 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
No brainer..go for the 540. I love 427's....but your friend has it right.
Tell us about the 540 combo.
JIM
Old Oct 18, 2010 | 12:26 AM
richiev88's Avatar
richiev88
JIM
Umm, its a std deck 502 block, forged JE flat tops, eagle 4340 crank,
mate has some RHS 360cc new alloy heads, have not worked out the cam yet, but 540 would need quite a bit of cam, may even just go hyd flat tapped...not sure, always had solid flat or solid roller in the past.
Would like a bit more compression, 10-10:5 think with the pistons and the 119cc heads about 9:5 according to the JE piston calculator
Old Oct 18, 2010 | 01:11 AM
427Hotrod's Avatar
427Hotrod
It's tough to get compression with the flat tops. 10.5 is a good range to be in. I started there...moved to 11.06 and now have it at 11.4. No problems on pump gas.
Do you have heads already? Those are pretty big for a low compression motor with a mild cam like you're describing.
JIM
Old Oct 18, 2010 | 01:41 AM
richiev88's Avatar
richiev88
[QUOTE=427Hotrod;1575652469]It's tough to get compression with the flat tops. 10.5 is a good range to be in. I started there...moved to 11.06 and now have it at 11.4. No problems on pump gas.
Yeah they are big, no I have not bought them yet ( he has several sets), can get smaller ones as well, perhaps a good excuse to up the cam and comp, suppose can mill the heads and deck the block, do you know how far you can go with this path with flat top pistons?
Old Oct 18, 2010 | 07:31 AM
L88Plus's Avatar
L88Plus
The original Pro Topline 320cc head is actually a better head than the 360 - decks are thicker and incoming air encounters a straighter shot at the back of the valve, the short turn is straightened considerably. Plus, they respond well to porting...
Old Oct 18, 2010 | 09:38 AM
cv67's Avatar
cv67
St. Jude Donor '05
Old Oct 18, 2010 | 11:12 AM
Ben Lurkin's Avatar
Ben Lurkin
St. Jude Donor '09
"reasonably priced" 540 is a bit of an oxymoron. You'll have to decide which plug wire to leave off for 600 hp.
That being said, I just built one for mine very similiar to what you're thinking. Search my user name if interested but Jim's (427 Hotrod) 'da man' when it comes to these BIG, big blocks.
360 heads are too big for the combo you're suggesting. Use 320's as discusses earlier.
Why the flat top pistons? Do you have those already?
Old Oct 18, 2010 | 03:26 PM
richiev88's Avatar
richiev88
Hi, the flat tops are part of the combo of new parts and block for sale locally, 502 block bored 4.5 to suit flat tops.
To be honest I think if I go down the big big block route I would like to run as much compression as possible, thus domed pistons. Yes Jims seems to be very knowlegeable on these engines
Old Oct 18, 2010 | 04:28 PM
c3_dk's Avatar
c3_dk
I would go for the 540
Old Oct 18, 2010 | 05:03 PM
L88Plus's Avatar
L88Plus
If you can't eat with the big dogs, it's best you just stay under the porch...
Old Oct 18, 2010 | 07:05 PM
tt 383's Avatar
tt 383
I will go against the grain , and say that you should definitely cam it, and run the 360cc heads, I don't know where these guys get there info from, but out of the box RHS 360 will flow 380cfm @ .600 & 400cfm @ .700 lift. Its not a 454, why build it like one? Mill the heads for desired compression.
Old Oct 18, 2010 | 09:52 PM
richiev88's Avatar
richiev88
Please explain?
Old Oct 18, 2010 | 10:12 PM
68sting's Avatar
68sting
Old Oct 18, 2010 | 11:20 PM
7T1vette's Avatar
7T1vette
Is your goal to build a particular vehicle or have raging power? If you have no need for the raw torque of a 540, don't go there. You will definitely need to upgrade the drivetrain in order to make use of that power without tearing up the drivetrain. If you don't want to go to that much trouble, just don't take the first step. You can do a number of things to a 427 to make it more "friendly" or "wilder". But, if your vision is not one of burning the wheels off the car, stay with the 427 (or 454) approach. If you stay with the smaller engine, you will not likely be the 'puny' kid on the block.
Old Oct 18, 2010 | 11:36 PM
Corey_68's Avatar
Corey_68
Also vote 540, but only only this forum will you hear a 427 or 454 is too small to get the job done.
Old Oct 19, 2010 | 12:36 AM
richiev88's Avatar
richiev88
I am torn, but leaning towards the 540cu. I love raw power, had a few laps in a 540 road race camaro, its was very addictive, but as you say destructive. I have had a many rides in a L88 replica, with a few improvements, that was no slug either, but I am over race gas engines for street use, its a pain in the ***!
I am worried that if i build a pump gas freindly 427 it will take away its character and the scary power......BUT it an only planning on running BFG's tires so I guess that will be the limiting factor with all this.
Maybe the answer lies some where between the 427 and the 540, I would like to keep the mechanical fuel pump too. If I dont have to pay for a date cast block and use a later 4 bolt 454 block will cut the cost heaps..... and a 502 block bored 4.5 scares me a bit for cooling ...
To 427cu or 540cu......
Old Oct 19, 2010 | 01:31 AM
davecour's Avatar
davecour
5555555555555444444444444444440000000000 0000 do it !! and add a little 871 to it should fit under the hood nicely
Old Oct 19, 2010 | 03:48 AM
roscobbc's Avatar
roscobbc
I went to 489 ci in using a stroker crank in a 'seasoned', re-built 454 4 bolt block. Brodix Race Rite oval port heads, hydraulic cam. With 500+ genuine hp and 550+ ft/lb torque it has similar economy to stock L36, still uses stock drivetrain, 3.08 rear end and M21 is great in traffic (with DeWitt rad). With these heads (stock height port location) it can still use commercially available headers although needed L88 type hood for carb/air cleaner clearance.
Old Oct 19, 2010 | 05:00 AM
panic's Avatar
panic
I've been thinking to replace my fearless 575hp 406ci SB engine with an upgraded one, can't make up my mind...
Here are two 750 hp option from ''American Speed'' engine builder (I have one of their 575hp 406 SB since a few years now and never had a prob...I reckon they're top guys hands down...), one is a supercharged 406 SB, the other is an ''atmospheric'' 540 BB...
1) 406 CID Brutus 750 Supercharged engine
Dart engine block, Comp Cams roller hyd. roller cam, 210 CNC comp. ported aluminum cylinder heads, ASE 4340 steel crankshaft, ASE 4340 6" steel rods, JE 8.0 comp. pistons, Mallory dist, alum. water pump, Pro Systems blower carbs...
750 hp $16,695.00
2) 540 CID Brutus 750 engine
AFR aluminum cyl. heads, Dart iron block, Comp roller cam, ASE 4340 steel crank and rods, Canton oil pan, JE 10.5 forged pistons, Pro Systems 950 carb, Mallory dist...
750 hp $14,995.00
3) Same as above but with alu Brodix block....17.895 usd.
All above price are for long blk engines, you need to add another 2.500 usd on top of that to make them full and ready to go...
Which one would you choose for my application?
My C3 has been lightened down to 2.750lbs so lightness is one of my top of the line priorities.
(...and sorry for the small hijack...)
