horn problem
Old Oct 26, 2010 | 05:29 AM
justatoy's Avatar
justatoy
Default horn problem
tested horns are good now what do i check..thanks
Old Oct 26, 2010 | 07:49 AM
jnb5101's Avatar
jnb5101
the horn relay closes when the horn button grounds and completes the coil circuit. pull the (black, i think) wire off the coil and ground the terminal that it was attached to. the coil should close and sound the horn. if it doesn't sound, suspect the relay. if it does sound, look to the horn contact switch (the round part under the horn button). remove the contact and ground the spring loaded button that you'll see. if it sounds, it's the contact that's bad. there's two steel plates in the contact that rust and prevent proper current flow and prevent the circuit to ground. you can repair the switch by carefully knocking out the three nylon rivets, dis-assembling the contact, wire brushing the plates and reassembling. but, if the horn doesn't sound when you ground the spring contact button, there's an open wire between the horn relay and the horn contact.
Old Oct 26, 2010 | 09:41 AM
7T1vette's Avatar
7T1vette
The lights??? What's your problem? [jnb5101 gave a good synopsis of the horn system, if that's what you need]
Old Oct 27, 2010 | 04:55 AM
justatoy's Avatar
justatoy
Default horn
Fixed thanks
Old Oct 27, 2010 | 08:21 AM
...Roger...'s Avatar
...Roger...
OK 7T1 I have to ask, what's this about ?
Old Oct 27, 2010 | 09:50 AM
7T1vette's Avatar
7T1vette
Just wanted to know what the "problem" was. All the OP said was that "the horns tested good". So... what's the problem? horns on all the time...no horns...intermittant horns....horns come on when the radio is turned on???? Just asking for some [needed] information.
Old Oct 27, 2010 | 11:16 AM
...Roger...
OK I got it now,thanks , I kept looking above for "lights" being mentioned , thought maybe I was missing something.
Old Oct 27, 2010 | 01:27 PM
justatoy's Avatar
justatoy
sorry guys the problem was could not get horns to sound from wheel and tested the horns and they worked found a broken wire near horn relay thanks
Old Oct 27, 2010 | 02:38 PM
7T1vette's Avatar
7T1vette
Since that was your problem, jnb's system overview was a big help, I'm sure. Glad you found the fault.
To horn problem
