On my '81 Vette the #1 plug is plugged in at the 8 o'clock Position on the distributor. On all my Chevy cars in the past, both carb'd and EFI the #1 was always at the 5 o'clock position aka pointing towards the #1 cylinder. I am assuming this was done because the dist. was not dropped in with the rotor pointed to #1 by the previous owner. I am going to be doing a full tune up on the car soon and was wondering it would be okay if I re-dropped the dist., moved the #1 wire to the 5 o'clock position and follow the firing order around? Anyone else run in to this?
For a "correct" installation, the HEI distributors were installed in the engine with the distributor's top plate and coil "square" in the engine compartment. In this orientation, the #1 plug wire was always installed at the forward, driver's side position in the cap (5 o'clock as viewed from the front).
The Chevy points-style distributors (1974 and earlier) always had the #1 plug wire installed in the forward passenger side tower (7 o'clock as viewed from the front).
Very interesting info. I just don't like it not being correct. I will check to see if the current routing is for the benefit of the ignition shielding. If I not I will be re-stabbing it in a few weeks. Thank you for all the information everyone.
Often, the reason for 'shifting' the plug wires is so that the vacuum advace can will be pointing directly to the right side of the car (for convenience of access) and availability to the dwell adjustment 'window'...while still having adequate timing adjustment movement for the distributor. As long as you are doing all the work on it, you can put it wherever you like. But if you do something "creative" and then take it to someone else for work, you'd better label your changes very clearly.
Was there a particular reason you did it this way?
my #1 wire was 6'' to long but really there was no reason it just kinda happened to be there when i dropped it in there is there any reason i should move it to the 5 o'clock position or should i just leave it and label them?? it was a pain being my first dist. to get it lined up properly with the gear and all
Also to prevent the tach drive cable from having too great an angle and frying.
My "Distributor Installation" paper has photos of the correct installed configuration of the points-type distributors, including the GM Service Bulletin that re-clocks the distributor for the tach drive cable problem. For copy of the info, just e-mail a request.
