Hot engine bubbled paint?
Old Nov 1, 2010 | 05:05 PM
tristan69's Avatar
tristan69
Default Hot engine bubbled paint?
I have a small bubble in my new paint and the paint shop told me it is because my engine is too hot.
I agree that my motor and headers run hot, but so do a lot of Vette's.
Would this cause a bubble or are they just looking for excuses?
I have some Reflect-A-Cool, constructed of fiberglass material backed with a layer of aluminized reflective foil to handle direct continuous temperature of 400°F and was thinking of sticking it under the hood.
I am fighting for them to strip and re-paint at the moment.
Old Nov 1, 2010 | 05:10 PM
BryanB75's Avatar
BryanB75
If you have no insulation under the hood now I can see that happening
Old Nov 1, 2010 | 05:16 PM
TERRY CLARK's Avatar
TERRY CLARK
.......Where's the bubble ?
Old Nov 1, 2010 | 06:24 PM
billsfan's Avatar
billsfan
Engine paint is good to 500 degrees. Unless your bubble is right next to a header, the engine never sees 500 degrees, gotta be the painter.
Old Nov 1, 2010 | 06:28 PM
tristan69's Avatar
tristan69
It is smaller than half a penny and under the motion stripe on the driver side right above the valve cover.
Stock insulation no longer fit with this motor, so I guess the Reflect a cool will be used.
Note the stinger was added by me and it was glassed in and allows the engine to breath better.
Mashman's Avatar
Mashman
Where the bubble is located might indicate why it's there. They don't happen to be above the AC compressor do they? Also, what do the bubbles look like? Can you post a picture?
Old Nov 1, 2010 | 06:32 PM
tristan69's Avatar
tristan69
I guess I was not clear that the paint bubble is on my hood, right above the driver valve cover. Engine oil temp is 210+ deg and I have not used a heat gun yet to see the header temp, but I agree that it should not bubble.
I have seen top fuel drag cars that run way hotter with fiberglass bodies and the paint does not bubble.
Old Nov 1, 2010 | 06:38 PM
tristan69's Avatar
tristan69
Body shop just called and they decided to sand it down and look at the glass work. They now think it was part prep on their part as my glass work looked good. They said they thought I could have air in the glass and that bleed out over time (WTF). They agree with the Reflect a Cool and will fix it this time on their dime.
Lets hope it does not bubble this time, but I might also wrap my exhaust to keep heat in.
I am still curious to how hot you can get paint on fiberglass before you get problems.
Old Nov 1, 2010 | 06:48 PM
SteveG75's Avatar
SteveG75
Factory insulation was for noise NOT heat. This sounds like a prep issue.
Need more photos. Looks like a nice paint job.
Old Nov 1, 2010 | 07:42 PM
7T1vette's Avatar
7T1vette
My 'opinion' is that the paint folks used some sort of volatile cleaner/prep fluid prior to paint and that some of it stayed in the glass. That stuff has to be purged by heat before painting or what you are seeing will be the result. Putting an insulating blanket under the hood is probably a good idea, because more of the same could occur.
Old Nov 1, 2010 | 08:00 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
Thats exactly what it sounds like.
Old Nov 2, 2010 | 02:06 AM
whitehause's Avatar
whitehause
I agree with the prep problem. I had the same thing on my 68 and it wasn't on the hood. It would only happen on hot days when the car was in the sun(black car), and would shrink back down to unnoticeable once it was back in the garage and cool. If it was engine heat, 1/3 of your hood would bubble, not just one tiny spot.
Old Nov 2, 2010 | 04:31 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
They just wanted an execuse. My car is a BB (a lot of heat!) with no hood insulation and the paint has not been damaged due to heat for 39 years.
Old Nov 2, 2010 | 09:37 AM
TERRY CLARK
I don't hardly buy the heat thing, looks like a bigger area would be affected ! Nice looking car !
Old Nov 2, 2010 | 10:20 AM
redstingray74's Avatar
redstingray74
Kool that the shop is standing behind their work . I tend to agree on the fact that if engine heat caused it ; a lot bigger area would be affected. Some of the new "thin " high tech insulation might be a good idea . I have a set of Chrome Hooker sidepipe headers on my '74 L82
and the radiant heat is no problem except for me when trying to mess with stuff before the engine cools. You just got to be real
careful routing plug wires !!! I do not agree with wrap for headers
as I have heard it can create problems under the wrap by confining
the heat instead of it dispensing normally.
And also that stinger in the middle of your hood looks really ,
really nasty!!!! Good job !!! Love your car.
Old Nov 2, 2010 | 11:03 AM
mlibhart's Avatar
mlibhart
I recently purchase a thin insulating product called "Lava Mat". It works great, AND it is a dark carbon fiber in color as opposed to the foil look. I'll warn that it IS expensive, but... here is the webpage:
http://www.heatshieldproducts.com/lava_mat.php
Old Nov 2, 2010 | 03:55 PM
tristan69's Avatar
tristan69
I tried to call and I get a message, also of the 2 distributers in Canada one closed and the other does not carry it.
Do you know if it sticks well under the hood and what the cost is for the product?
Also a picture of the underside of your hood would be great
(with the Lava Mat)
I figure if it sticks well and looks good I will buy one of the following:
770003
Lava Mat™; 36" x 48" with adhesive
770005
Lava Mat™; 60" x 48"; with adhesive
I do not like the silver look under the hood as much as this look.
To Hot engine bubbled paint?
Old Nov 2, 2010 | 05:50 PM
mlibhart's Avatar
mlibhart
There is a link on the webpage I originally posted for PACE. That is where I bought mine. They shipped promptly and no problems. I used it to isolate the starter and solenoid. However, it has a very good adhesive (I'm sure it is same as used on Dynamat and other similar products). I can't imagine it would be a problem on the underside of the hood. As I said, it is very pricey. If I recall, the 4'x6' piece is around $150. !!!
Old Nov 2, 2010 | 05:53 PM
mlibhart's Avatar
mlibhart
Following up.... here is the PACE webpage for Lava Mat:
http://paceperformance.com/search.html?q=lava+mat
Old Nov 4, 2010 | 03:39 PM
tristan69's Avatar
tristan69
Wow $300+ taxes and duty to get this up to me here in Canada.
Someone is making money
I am looking at this now:
http://hoodliners.blogspot.com/
http://cgi.ebay.ca/1977-1982-Corvett...item2c588e8f21
The 3M 80 spray glue is not sold in Canada so I need to find a replacement or drive across the border to get it.
This post talks about it but no one really says how much heat it cuts down or how well it sticks after a few years.http://forums.corvetteforum.com/c3-g...post1575820111
I would hate it to drop on the engine while driving a few years down the line and catch fire.
