Where can I source a new frame-to-engine block ground strap?
Old Nov 2, 2010 | 07:12 PM
mar's Avatar
mar
Default Where can I source a new frame-to-engine block ground strap?
My engine block ground strap is toast - can I buy one or can someone recommend someone that can make me up one??? Thick, stranded copper wire with black insulation and big, crimped-on ends for the bolt attachments.
Old Nov 2, 2010 | 07:39 PM
Alan 71's Avatar
Alan 71
Hi mar,
The usual vendors have them; and some people make their own.
Regards,
Alan
Old Nov 2, 2010 | 07:48 PM
Grumpy 427's Avatar
Grumpy 427
Any Battery store will cary something. I made both of mine.
Old Nov 2, 2010 | 08:03 PM
mj9311's Avatar
mj9311
i made mine also... quick and easy but an autozone or such should have what you need
Old Nov 2, 2010 | 08:19 PM
BKbroiler's Avatar
BKbroiler
I got one either from Corvette Central or Mid America.
Old Nov 3, 2010 | 12:41 PM
markdtn's Avatar
markdtn
You can make it with parts from Tractor Supply or NAPA. Also big truck dealers will have or can make those (Peterbilt, Kenworth, Freightliner, International, etc.)
Old Nov 3, 2010 | 03:04 PM
76stingracer's Avatar
76stingracer
Any parts store will have them. Just check out the battery cable section.
Old Nov 3, 2010 | 03:12 PM
SOMFormula's Avatar
SOMFormula
Like stated above.
I found Autozone to have a good selection. I always get the (numerically) smallest gauge I can find for the specific application. Meaning, the higher the # gauge of the wire, the more flexible it is.
The battery "aisle" usually has what you need. With different terminated lugs, too!
Old Nov 3, 2010 | 03:47 PM
wcsinx's Avatar
wcsinx
Is that the one that goes to the passenger side motor mount? Mine was in a similar condition, and I got a replacement right off the rack at Advanced Auto.
Old Nov 3, 2010 | 04:09 PM
7T1vette's Avatar
7T1vette
2 ga. welding cable and two crimp (or solder ends is better) lugs will get the job done.
Old Nov 3, 2010 | 04:17 PM
Roco71's Avatar
Roco71
If you have a welding supply store close by you can buy the cable and ends and make your own.
I guess I type slower than 7T1
Old Nov 3, 2010 | 05:23 PM
SOMFormula's Avatar
SOMFormula
Like stated above.
Old Nov 3, 2010 | 05:26 PM
joewill's Avatar
joewill
got mine at target, it is maybe 4 inches too long, but so what... better than twice the price plus shipping for one at the covette parts houses.. i am sure napa or autozone will have something close too.
my car started and ran and charged fine without it anyway even before I replaced it... I am sure other grounds in the system take up the current needing to pass thru anyway.
Old Nov 3, 2010 | 07:07 PM
7T1vette's Avatar
7T1vette
You shouldn't alter the size of the wire for flexibility. The wire size is defined by the amount of current it needs to carry. So, don't mess with the #2 gauge wire (you can go larger, of course...#0 or #00...but not necessary). The flexibility is enhanced by the number of strands in the wire..the more strands in a particular size of wire, the more flexible it is. Stay with #2 copper wire. Welding cable is very flexible, as it is constructed of lots of little strands of wire.
Old Nov 4, 2010 | 06:19 AM
mar's Avatar
mar
Thanks to all - I got a 12" one from NAPA - 4 bucks! Installed last night perfect.
Old Nov 4, 2010 | 09:59 AM
cv67's Avatar
cv67
St. Jude Donor '05
Napa also sells the flat silver braided type, look nice and real reasonable.
To Where can I source a new frame-to-engine block ground strap?
