Side pipe mufflers
Old Nov 14, 2010 | 03:43 PM
STODD's Avatar
STODD
Default Side pipe mufflers
I know this has been debated in the past, but hoping to get recent info. Finally have my Hooker headers and sidepipes installed on my 406 small block, way too loud with no mufflers, the used glass pack style mufflers I have installed are way too restrictive, basically routing 4 1 7/8 primary pipes into one 1 7/8 pipe in the glass pack.
What are you guys running?
Thanks, Steve
Old Nov 14, 2010 | 03:57 PM
SteveG75's Avatar
SteveG75
STS baffles. Only way to fly. Sound great at WOT and can listen to the radio, top down, at cruise.
Old Nov 14, 2010 | 04:29 PM
lars's Avatar
lars
Same as Steve: STS (Turbo Spirals). Fantastic sound and performance (I'm running a 407 dyno'ed at 496 hp). I even drilled the caps open 1/2" to get a little more music out of them:
Lars
Old Nov 14, 2010 | 05:21 PM
kunkle's Avatar
kunkle
Agreed. Don't even bother with the glasspacks. You can listen to the radio though?- I must need a more powerful stereo ;
Old Nov 14, 2010 | 05:54 PM
lars's Avatar
lars
Steve shuts the engine off and coasts down the hills...
Old Nov 14, 2010 | 08:49 PM
ragtag74's Avatar
ragtag74
Sweet thunder 2 3/4 inch inserts John
Old Nov 15, 2010 | 05:33 AM
STODD's Avatar
STODD
Has anyone tried hookers Max Flow 21046HKR? They say they dyno better than open headers and are $200 cheaper than STS Baffles
Old Nov 15, 2010 | 08:20 AM
U17's Avatar
U17
sweetthunder.com .... '76,ZZ383 ...
Old Nov 15, 2010 | 02:17 PM
LannyL81's Avatar
LannyL81
I have them on my '81 with mild rebuild. They make a nice roar at WOT. Crusing is fine....able to talk and hear the radio with windows down....just not a WOT.
I tried no inserts, but that was way too loud. These are fine for my ears and engine.
Old Nov 15, 2010 | 02:25 PM
auavette's Avatar
auavette
STS baffles uncapped
Old Nov 15, 2010 | 03:45 PM
blckslvr79's Avatar
blckslvr79
STS baffles- capped
Old Nov 15, 2010 | 03:55 PM
Phil Zell's Avatar
Phil Zell
got em on mine and like them, 383 cid
Old Nov 15, 2010 | 04:52 PM
sokoloka's Avatar
sokoloka
Sweet Thunder 2 1/2" inserts - sound great.
Old Nov 15, 2010 | 06:24 PM
'75's Avatar
'75
I have the sweet thunder 2 1/2 inserts and the noise is unbearable on the highway. I would not recomend them.
Old Nov 15, 2010 | 11:09 PM
redman76's Avatar
redman76
St. Jude Donor '09
STS baffles w/ 1/2" hole drilled in cap.
Old Nov 16, 2010 | 12:09 AM
glackore's Avatar
glackore
Definitely STS baffles uncapped! Awesome sound and performance.
Old Nov 17, 2010 | 06:10 PM
STODD's Avatar
STODD
I ordered the hooker max flows from summit today for $165. Will give feed back when I get them installed.
Thanks for all the advise.
Steve
To Side pipe mufflers
Old Nov 18, 2010 | 12:38 PM
iNdigo's Avatar
iNdigo
I'm running the largest size (2 1/2 inch?) max flow mufflers from hooker, and they definitely flow better than the old hooker reverse flow mufflers. For the price, I personally couldn't justify the STS units.
I've been very happy with the max flow units.
tbw
Old Nov 18, 2010 | 09:51 PM
cboyd's Avatar
cboyd
Originally Posted by blckslvr79
STS baffles- capped
Old Nov 21, 2010 | 11:43 PM
corvettedale's Avatar
corvettedale
Cruising
I am running the Hooker Max Flo....They are noisy but I like them and my buddies do too..
Running a solid lifter, aluminum head 383...
