got a 74 auto(th400) with 4.56 rear gear 225/70 r15 tires trying to find out where i can get and what speedo gear i need as you can guess it is wayyyyy off..
You'll have to get a ratio correction box made up at a speedometer shop. With 4.56 gears and a T-400 you wont get close with any possible drive and driven gear combinations.
The box attaches to the transmission where the cable attaches and the the cable attaches to the ratio ciorrection box.
It must be quick out of the hole but the engine has to be screaming at 70 mph.
Why bother? With that gear you can't go very fast, anyway. You just get there really quick!!!
Seriously, you will have to get a conversion box. The internal drive gear would need to be changed to accommodate the new 'driven' speedo gear also. That would mean removing the tranny. Call some tranny shops around your area or check on the internet for "speedometer ratio adapter".
Good for Drag Racing ONLY, now, I would ditch that 456 gearset as being totally useless on the street....even with overdrive, unless you had a .5-1 overdrive ratio.....like a 6th gear....and THAT would cost a fortune....
yes, you will have to do the math and fiqure out exactly what ratio conversion you need based on speedometer drive gear, speedometer driven gear, tire diameter, rear end ratio.
you need to figure out what conversion ratio you need by installing a ratio adapter that will force your speedometer cable to spin 1000RPM at 60MPH.
use a GPS to get real 60 MPH speed and eyeball your speedometer to get your error factor at 60 MPH.
for example, if your GPS says 60 MPH and your speedo says 70 you need to slow down your cable spinning.
i originally had 2.73 and had a hellve deal for a complete rear off a front end totaled 68 with 4.56 for $100.00 i couldn't say no to that..but your right i was thinking maybe 3.73's?
Why bother? Just disconnect the speedo cable and use the tach to judge speed. I ran 4.56 in mine for awhile. 54 mph at 3000 rpm. Believe me, you'll be changing them before too long.
