interior experts only
Old Mar 31, 2011 | 06:04 PM
forman's Avatar
forman
Default interior experts only
Ok when I bought my car the console was just sitting in place it was split so I bought a new one .In the mean time I dyed everything ,new carpet , door panels ,put the carpet in the back ,,so I went to put the console back in the car and it wont go in all the way I dont want to force it back in place and break my new console or the dash panels So I thought maybe I missed something when I put the dash and the panels back in .I dissasembled the whole dash again ,panels, dash, center console everything it was all tight when I took it out , so I put it all together again dash clips were in place everything tight as a drum went to put the console back in and still it wont go back in this is driving me crazy and i am about to burn the car to the ground ,, It appears that the console is about 1 1/2inches from the side mounting plate and it has to go up a inch .I measured the copnsole its the same as the old one I even took the mounting plate off the console and that wasent it either,,my only thought is that the panels are warped so bad that It wont allow the console to get in there any sugestions would be helpful sorry for the rant but I had enough already
Old Mar 31, 2011 | 06:21 PM
Alan 71's Avatar
Alan 71
Hi f,
What year are you working on?
For the early 70 cars that I'm familiar with the shifter console needs to be in place, with the screws loosely installed, before the dash pads and center gauge bezel are installed. I also make sure the emergency brake console will fit too, before tightening ANY of the dash or console screws.
Perhaps your sequence is the cause of the fit trouble?
Regards,
Alan
Old Mar 31, 2011 | 06:30 PM
forman's Avatar
forman
Alan alway a plesure my freind ,, yes its a 70 all the scews were loose when fitting the console its so far off ,,, I just poured myself a large vodka drink
Old Mar 31, 2011 | 07:26 PM
forman's Avatar
forman
I found my problem but I cant tell ya!
Old Mar 31, 2011 | 07:44 PM
DZRick's Avatar
DZRick
LMFAO!!
Don't ya just hate those moments?
You know you're going to have to tell us, don't you?
Old Mar 31, 2011 | 07:58 PM
forman's Avatar
forman
Naa not yet !!
Old Apr 1, 2011 | 12:17 AM
7T1vette's Avatar
7T1vette
Hey, it's OK that the console was installed small-end forward. We all understand that, sometimes it just doesn't go our way.
P.S. glad you found the problem and....we don't want to know...
Old Apr 1, 2011 | 11:10 AM
spinadog's Avatar
spinadog
After struggling with my own interior, I do want to bathe in someone else's suffering!
Please tell.
Old Apr 2, 2011 | 11:16 AM
oldsarge's Avatar
oldsarge
It is time to tell, I am curious, don't be shy, we have all done some stupid things at one time.
Old Apr 2, 2011 | 12:00 PM
forman's Avatar
forman
so it was a few factors ,,carpet was in the way & the vent cables were getteing in the stud holes and the heat adjuster was binding against the vent cable on the left side I got it back in and I am about a week away from finishing my interior ,I will post pics when Iam done.
Old Apr 2, 2011 | 06:29 PM
oldsarge's Avatar
oldsarge
That wasn't so bad, at least you figured it out, good job. Looking forward to seeing pics of the new interior.
Old Apr 2, 2011 | 08:21 PM
jcloving's Avatar
jcloving
I had similar problems when putting my 76 back together. I could not fit the shifter console in place. I had put the gauge cluster in too soon.
I pulled it out and then the shifter console went in place. I also changed from the small screw nutclips to larger #6 screw nutplates and put in small #6 bolts thru the shifter console with small fender washers. The gauge cluster is a tight fit but it fits.
When time came to put in the parking brake console, I had to trim some carpet, move some cables that were getting pinched and remove some insulation behind the bolt point. When that was done, everything fit as it should. Tight but it fit.
I work on the car in 2 hour bursts. When I have a problem I usually sleep on it or research it here.
John
Old Apr 2, 2011 | 08:35 PM
forman's Avatar
forman
Well I am still working on the interior. Not tonight cause I am at the casino trying to win some cash for my paint job ...
To interior experts only
