Are all C3 windshields the same?
Old Apr 3, 2011 | 09:50 AM
Jackk's Avatar
Jackk
Default Are all C3 windshields the same?
My windshield, which was installed by a PO does not seem to fit right. It seems to curve a little tighter at the sides than the frame or T tops. It leaves a gap at the top and bottom of post.
Thanks Jack
Old Apr 3, 2011 | 01:59 PM
Alan 71's Avatar
Alan 71
Hi Jack,
Is the extra 'gap' between the glass and steel frame, or between the glass and a-pillar ss trim?
Regards,
Alan
Old Apr 3, 2011 | 02:54 PM
doctorgene's Avatar
doctorgene
I want to hear the answer to this ??? Thanks Gene
Old Apr 3, 2011 | 03:09 PM
wombvette's Avatar
wombvette
They are the same contours. They are not all the same shape on the perimeter at the bottom.
Old Apr 3, 2011 | 09:32 PM
Jackk's Avatar
Jackk
The gap is at the top between the glass and the SS trim and at the bottom corners. I took some pictures
Old Apr 4, 2011 | 11:09 AM
myk7's Avatar
myk7
It looks to me as if there are 2 problems, one easily fixed. The center windshield trim should go farther behind the side trims, that should fix the center piece gaps. It also appears the windshield was installed too low. It's been a while, but I believe there should be 2 rubber spacers at the bottom of the windshield, are they there?
Old Apr 4, 2011 | 02:14 PM
Jackk's Avatar
Jackk
What's hard to see in the pics is that the gap under the center ss trim is also under the ss steel trim on the a pillars at the top corners. There are no spacers that I can see anywhere under the glass. So it looks like the entire windshield is installed too far in.
Old Apr 4, 2011 | 02:37 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
I just had my windshield replaced in my 77 with a later model one.. it has black up the pillars and along the bottom.. I Wasnt sure I was going to like it, but I really do...
Now as for the gap.. I also have a nice gap on the upper area. .. Stupid me I Was a t a car show on sat and didnt look at single other car to compare. but i did look at a car at the shop i go to.. its an in molested 71 and it also has a little gap.. so ... HUH.. sure wish I would have looked this weekend..
Old Apr 4, 2011 | 03:21 PM
BBCorv70's Avatar
BBCorv70
The gap I see, lookng up, at the top near the pillars looks quite large compared to the gap I see moving toward the center. Could be an illusion but it looks like the contour is off? If the bed which the glass sits in were raised to fix the gap at the column, this would have the glass sticking out in the center?
Who made the glass? The local Corvette shop I deal with complained about a lot of junk out there for new windshields. Some too narrow, thinner, etc.
I just had mine replaced. Mine came from Pilkington. I think they're the ones who bought LOF glass? Fit seems fine on my 70.
mrvette's Avatar
mrvette
I HEAR there not only different thicknesses of WS sealing/mounting compounds, but maybe two different types....
I also know that years ago I sealed my W/S in with black RTV, totally sealing the entire area so that no matter what, NO water gets behing the stainless, OR that area next to the glass from the fender trim....
not possible to rust,
the stainless trim tends to fit with 'tolerances' all over the place, on these cars....without a better look, I can't say any more....
Old Apr 4, 2011 | 04:00 PM
Jackk's Avatar
Jackk
I can't find a manufacturers name on it anywhere.(can't be a good thing). BBCorv70 your right. Thats no illusion, and thats what has me confused. mrvette you are right too, looks like the SS trim has been contorted to fit a bad situation.
Old Apr 4, 2011 | 06:26 PM
BBCorv70's Avatar
BBCorv70
The manufacturer's label is usually on the bottom right corner.
Old Apr 4, 2011 | 06:38 PM
volition's Avatar
volition
Take the SS trim off the top and take a picture of the gap with the T-Tops off. It's just held on by clips.
This should give us a good idea if it's the glass that's messed up or if it's simply installed too low on the frame.
Old Apr 5, 2011 | 11:10 AM
hugie82's Avatar
hugie82
In 78 GM said it was using thinner glass for weight savings but I'm not sure if that included the wind shield???
Old Apr 5, 2011 | 11:13 AM
tracdogg2's Avatar
tracdogg2
I'm seeing this more and more often. Inferior (cheaper) C3 windshields on the market. You want LOF brand glass. Whoever installed it did in incorrectly. It looks like they just glued it in flush. It has to be installed 3/8 off the frame. That's why you have the gap at the top.
Mike
Old Apr 25, 2011 | 10:08 PM
mn_leaf_fan's Avatar
mn_leaf_fan
I'm not trying to hijack this thread, but here is another example of ill-fitted glass.
I just bought my 75 and was caught in the rain. Front glass leaked like a sieve.
Upon closer investigation it looks like the glass is installed too low... you can see the top corners of the glass under the trim.
Sorry about the bad pics.....
Old Apr 26, 2011 | 04:35 PM
Alan 71's Avatar
Alan 71
Hi,
Here's a picture of a more typical fit for the glass and trim.
This is a replacement windshield from Classic City Auto. (Not in-expensive at all!)
The ss trim is all the original pieces. There isn't any gap between the bead on the ss trim and the glass.
I'll bet the glass was glued in without test fitting ALL the trim. It's a bit of work to dry fit it; but does away with any nasty surprises!
I think the trim needs to come off to see what's going on and what a solution might be.
Regards,
Alan
To Are all C3 windshields the same?
