I have a 70 vette I am restoring and it has black interior. 50% of plastic interior trims/seat backs/etc are in pretty good condition and 50% need to be replaced. Since I have to replace 1/2 anyway, I am changing interior color to red. Personal preference.
My question is, were the original interior plastic trims/back/etc just PAINTED the color of the interior or was the color mixed into the plastic mold/trims? IE Can I paint the good black pieces with red or would that be CHEESY and start fading/peeling? My vette is a 454 (hot) and convertible (weathered) and I want the job to look good, last, and be "near original".
And if they painted them anyway (like all parts were stock black and they painted them red/blue/tan/etc, which is best spray/paint to match the original red interior? Any help would be greatly appreciated. Thanks.
Hi s,
In brief, I'd say to try to re-use what EVER interior parts you can.
The reproduction parts are notorious for not fitting well, or at all, without modification.
7T1 has lots of good information on how to change interior color successfully. Perhaps he'll see your thread and pipe up.
Regards,
Alan
Do a "SEARCH" on vinyl dye. There are lots of reasons to use vinyl dye (or, elastomeric recoloring agents) to recolor plastic/vinyl parts. There are also lots of reasons NOT to 'paint' them with standard spray can stuff. Read the threads and do what you want.
I agree with the vinyl dye. I bought from CA and it sprayed very easily. just use the prep then spray. I just bought a bunch of parts for my 72 interior and the seat backs, console and all were sprayed, the dash was formed in color. And yes the aftermarket parts dont fit very well!
Rodney
I've had great success with the SEM product line. I did the dash on an El Camino I used to have. I replaced the one in my car that had been cut up quite a bit with a cream/tan one from a junk yard. Just cleaned it good and used SEM black. Before and after pics....
I would highly recommend using SEM vinyl dye (ColorCoat) in liquid form and spraying...either with your own equipment or with a $5 PreVal bottle/gas sprayer you can buy at the same store as the vinyl dye [professional auto body paint supply store is the best choice as they can mix to the GM interior code or match a piece that you bring in].
Yes and no. Although most plastic pieces were molded in the color, I imagine there could have been the need to use a different color piece to fill an order. Which then would need to make a trip to the body shop for a coating of Dupont vinyl color.
Once the stock of any color piece would be depleted, the process would be the same for coloring. Then for service pieces they were all made in any color you wanted.... as long as it was black. Obviously much more economical to make one color and" paint to match". (which is the phrase that came along with the part).
The dupont held up very well on the hard plastic/metals. Since all the soft vinyl was molded in the color, there wasn't a need to color it even though it could be used for it, being a elastomeric.
Dupont is very difficult or impossible to find, being the colorant is no longer made. I always felt the color match was the best, and more importantly, the sheen level for the different pieces was dead on.
Nowadays SEM appears to be the product of choice as stated. Good luck
This is what I was able to find in Australia and I was very happy with its coverage, color match and sheen levels.
A Pillars and header are new parts.
B Pillars and center T Top center panel are new.
It took 2 attempts with the paint supply shop to get it 100% in my mind on the color match. Gave them a few panels and they kept mixing and spraying till we were both happy.
