Engine Compartment Paint
Old May 2, 2011 | 11:43 AM
bill69's Avatar
bill69
Default Engine Compartment Paint
I am rebuilding my 70 454 motor due to a piston failure. I want to paint the block, heads, oil pan, intake, exhaust manifolds, master cylinder, water pump, engine compartment...etc..but i am not sure how it came from the factory. What parts are chevy orange, what parts are black, what parts were gray/aluminum? What about the bolt heads were they orange or natural? What about the fiber glass in the engine compartment, was that naturally a black color, was it painted? I would appreciate any help you can offer.
Old May 2, 2011 | 12:41 PM
kaiserbud's Avatar
kaiserbud
I will have to check, as I cannot recall off hand. But way back when I started my restoration, the CF guys guided me on the appropriate paints in various areas. they also suggested purchasing the NCRS Restoration guide. If you search for both wthin CF, you will find plenty of threads.... even specifically on engine compartment paint colors - most likely one of my threads inquiring the same question.
Good luck ,....
Old May 2, 2011 | 03:14 PM
cv67's Avatar
cv67
St. Jude Donor '05
The Summit racing chevy orange paint is a very nice match imo for factory. Too many are on the bright side. dont know if this helps.
Old May 2, 2011 | 04:20 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by bill69
...I want to paint the...block, heads, oil pan, intake, water pump, bolt heads...
Chevrolet orange
...exhaust manifolds, master cylinder...
Unpainted, although some master cylinders were semi-flat black.
...What about the fiber glass in the engine compartment...
Slight overspray from exterior color; semi-flat black from blackout.
69 here; 70 would be similar.
Old May 2, 2011 | 04:36 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Chevrolet orange
I think the '70 came with a painted intake manifold, the same chevy orange as the rest of the engine.
Old May 2, 2011 | 04:52 PM
Alan 71's Avatar
Alan 71
Hi Bill,
I, too, suggest you buy the NCRS 70-72 TECHNICAL INFORMATION MANUAL and JUDGING GUIDE.
In the manual you'll find lots of information about what was painted, (and what color), what was plated, (and what type of plating), and what parts were left 'natural'.
The Eastwood catalogue has a WIDE variety of paints and finishes to duplicate the original finishes. So call for one of their catalogues too.
Here are a couple of pictures to encourage you.
Regards,
Alan
Old May 3, 2011 | 12:39 AM
spdrcr29's Avatar
spdrcr29
Regards,
Alan
Alan....i'm so jealous! I'm **** and retentive, but I don't think I could ever get my engine compartment looking as awesome as yours! Thanks for sharing!!
Old May 3, 2011 | 08:06 AM
Alan 71's Avatar
Alan 71
Hi spr,
Yes, you really can.
It's really more about TIME than anything else.
Regards,
Alan
Old May 3, 2011 | 08:23 AM
CFD E59's Avatar
CFD E59
Alan: Thats a work of art...& love
Old May 3, 2011 | 10:23 AM
bill69's Avatar
bill69
Thanks guys that is what i needed to know. Very nice cars by the way, i bet those don't get driven too much though.
Old May 3, 2011 | 05:07 PM
Alan 71's Avatar
Alan 71
Hi Bill,
You're right about the driving, now!
I did drive it though, a LOOOONG time ago! About 40k in a year and a half.
Regards,
Alan
Plus, if they don't make very much hp at least they should be pretty.
Old May 3, 2011 | 05:28 PM
qtlow's Avatar
qtlow
Alan, Do I actually see two things not correct on your car?
You've got a full shielded distributor cover and open element air cleaner.
I know you car is an early 71 but the change over to dual snorkel air cleaner and distributor cover top only took place late in 1970 on all small blocks except LT-1. At least I thought.
This is not meant as any disrespect but I could have swore your car was correct down to the caps on the valve stems of the rims.
Your car is a roll model regardless.
Old May 4, 2011 | 05:15 PM
centralcalvette's Avatar
centralcalvette
Alan, that is absolutely beautiful !! Is the heater box painted ? It looks "natual", but almost shiny like it's brand new. Is your firewall painted. looks the same way. Any help is appeciated.
Old May 4, 2011 | 05:58 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
[QUOTE=Alan 71;1577505379]Hi Bill,
Regards,
Alan
Alan, I still have not seen a pic of your whole car. You are teasing me with these pics! You are also encouraging me to dig into my engine compartment again and clean/paint/chrome some more. My wife already thinks I'm bats. Please give us a pic of your ride........
Old May 4, 2011 | 06:32 PM
Alan 71's Avatar
Alan 71
Hi qlw,
You're very right.
I ran a open air cleaner and 70 distributor box for years because I liked the look of them so much better.
Starting last fall I've been getting it ready for Flight Judging this Fall in honor of it's 40th birthday. Right now it does have the 71 air cleaner and ignition shielding on it.
I'm getting used to the look but will probably go back to the 70 parts after it's been judged.
Regards,
Alan
Thanks very much for the VERY kind comment.
Old May 4, 2011 | 06:37 PM
Alan 71's Avatar
Alan 71
Hi d,
Once I have the car prepared for Flight Judging I'll take some pictures.
So please be patient for a couple more months.
It's really just a very ordinary 71 coupe, with a bit of wacko attention detail.
Regards,
Alan
Old May 4, 2011 | 09:14 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
Hi d,
Regards,
Alan
It's not "wacko" if it's a labor or love. To me it's my relaxation time away from the job. I'll be waiting. Good luck, not that you will need it, you will have NO problem.
To Engine Compartment Paint
Old May 9, 2011 | 04:47 AM
hunt4cleanair's Avatar
hunt4cleanair
What's the best way to prep the engine for paint? Simple green and a toothbrush? And I'm not describing an engine that has caked grime This thread has motivated me to finally perk up the engine compartment.
My radiator has a leak and I've found an auto place that can run pressure tests and repair leaks. so, while I've got it out, I'll do the entire compartment.
Old May 9, 2011 | 04:49 AM
NIKONI's Avatar
NIKONI
2nd Gear
Very cool cars! that's exactly what i want yo know .
Old May 9, 2011 | 05:45 AM
richiev88's Avatar
richiev88
Hi Bill,
Regards,
Alan
Top job, looks great !
