Headlight Warning Indicator ?
Old Jun 9, 2011 | 10:05 PM
Ray Y's Avatar
Ray Y
Default Headlight Warning Indicator ?
On a '70, is the red warning lamp located on the center console cluster for the Headlights supposed to be lit if the lights are on and doors are open or if the lights are on and they stayed closed?
The Service Manual says "Micro switch on linkage must shut off warning lamp when lights are fully extended." Does extended mean open or closed?
Anyway mine is currently lit when the headlights are on and the doors are open. This seems wrong to me. At night I can tell if the doors are open and I don't need a big red light shining back at me for confirmation.
Old Jun 9, 2011 | 10:11 PM
...Roger...'s Avatar
...Roger...
Bad or broken micro,unplug it until you get a replacement and the light will go out.
If the lights don't come up all the way and lock this will turn the light on.
Old Jun 9, 2011 | 11:00 PM
Fonz69's Avatar
Fonz69
could need a little adjustment too
Mine comes on also but if I reach under and move the arm up a bit it contacts the switch and the light on the dash will go out
Old Jun 9, 2011 | 11:48 PM
7T1vette's Avatar
7T1vette
The red lamp signal comes on as soon as you turn on the headlights...and it goes out when the light buckets are up and locked.
Old Jun 10, 2011 | 06:14 AM
Alan 71's Avatar
Alan 71
Hi Ray,
The light should come on for just a second the instant you pull the headlight switch, and go off the instant the headlight doors are ALL the way open.
Here's a picture of the black plastic switch. There's one for each headlight. You can check to see if it's adjusted properly.
Good Luck!
Regards,
Alan
Old Jun 10, 2011 | 06:31 AM
DZRick's Avatar
DZRick
Originally Posted by Alan 71
Hi Ray,
Good Luck!
Regards,
Alan
Please put me in your will, Alan.
Just leave me your car. Pleeeease!
Damn, that car is perfect!
Old Jun 10, 2011 | 09:40 AM
Ray Y's Avatar
Ray Y
Thanks for all of the help/input guys. I think it's probably an adjustment issue. They were no microswitches in place when I bought the car 5+ years ago and I'm just getting around to making them work. The switches are new so odds are in the favor of an adjustment. I'll play with it over the weekend.
Alan-
Thanks for the pics! I agree with the other comment, your car is beyond immaculate. Did you ever get judged so we can finally see a full body shot of that baby?
Old Jun 10, 2011 | 10:20 AM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Your know he enjoys showing us his pictures...just as much as we enjoy looking at them.
Old Jun 10, 2011 | 10:26 AM
Mashman's Avatar
Mashman
The system will work with only 1 switch hooked up. So, I would connect the switches one at a time, and get one to work and then connect the other.
Old Jun 10, 2011 | 01:15 PM
DZRick's Avatar
DZRick
Alan like teasing us with pictures! I don't think anyone has ever seen a picture of the whole car.
I've got to say I don't mind though.
Old Jun 10, 2011 | 01:56 PM
KJW427's Avatar
KJW427
5th Gear
Hello guys, just joined and wondered if this is true for a 1969? I have not received my car yet, should be a week or so...
Old Jun 10, 2011 | 02:29 PM
qtlow's Avatar
qtlow
Default Just one.
Actually he did post one once.
But I'm sure it's going to be much nicer by the time he's done with it.
Sorry for digging this one up Alan but I just had to do it for all your fans and followers.
I can see it now, when you finally do reveal your completed work of art and post the photos that threads going to go 50+ pages long.
Old Jun 10, 2011 | 04:26 PM
Alan 71's Avatar
Alan 71
Hi,
Thanks for the kind remarks!
I'm thinking pictures of the whole car will be a bit of a let-down since you've already seen ALL the GOOD parts!
But they will come someday.
Regards,
Alan
Old Jun 10, 2011 | 07:00 PM
DZRick's Avatar
DZRick
I'll be damned, I think I actually saw this picture!
Hi,
Regards,
Alan
I seriously doubt it, Alan
Old Jun 11, 2011 | 07:15 PM
Ray Y's Avatar
Ray Y
It was an adjustment issue. Pad was not contacting the microswitch button on either side enough to depress the button.
Thanks for the help guys!!!
and ALAN-
Please don't wear a tie in the next picture of your Vette!!
I do remember seeing that photo previously as well. Actually very cool, you've had that car a very long time and it's very obvious that you still love it.
Old Jun 11, 2011 | 07:19 PM
Faster Rat's Avatar
Faster Rat
Originally Posted by Ray Y
and ALAN-
Hey Alan
This car must be a previous affair of yours. The one you are "doing" now is topless, correct?
FR
Old Jun 12, 2011 | 07:19 AM
Alan 71's Avatar
Alan 71
Hi FR,
You lost me now?!
Still the same car.
Regards,
Alan
To Headlight Warning Indicator ?
Old Jun 12, 2011 | 07:24 AM
Alan 71's Avatar
Alan 71
Hi Ray,
Yes that picture and tie are from a long time ago.
It's really odd the way EVERYTHING has changed since then, (Spring71), but the car.
I wore a tie to church a couple of weeks ago... probably the first tie this year.
Regards,
Alan
Old Jun 12, 2011 | 09:08 AM
Faster Rat's Avatar
Faster Rat
Hi FR,
You lost me now?!
Still the same car.
Regards,
Alan
For some reason I thought your car was a convertible. All we get are those little glimpses of the fine details....
Old Jun 18, 2012 | 04:31 PM
scf100's Avatar
scf100
Reading this old thread just solved my problem with the light too....thanks guys.....
