Add AC?
Old Jul 30, 2011 | 03:35 PM
jman1's Avatar
jman1
Default Add AC?
is it possible to ad AC to a 76 that didnt come with it? costs?
Old Jul 30, 2011 | 03:45 PM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
I would look at the Vintage Air kit. Some folks here have done it and seem happy with it.
Old Jul 30, 2011 | 03:54 PM
rugerm44's Avatar
rugerm44
Do a search.It's not bad to put on.It will run about 1300. If you put it on yourself.
Old Jul 30, 2011 | 05:02 PM
Alan 71's Avatar
Alan 71
Hi jm1,
Take a look at the thread by GD70 about adding a/c to the car he sold recently. (Search his recent threads.)
Lots of pictures!
And.... a TREMENDOUS amount of work.
Regards
Alan
Old Jul 30, 2011 | 06:34 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Which way to you want to go? You can purchase aftermarket kits or you can scrounge the parts together and install the optional factory AC system.
Old Jul 30, 2011 | 07:32 PM
Clubby99's Avatar
Clubby99
Better to go Vintage Air. It looks stock installed, modern components and works better. Probably cheaper to install too.
Old Jul 30, 2011 | 08:28 PM
jman1's Avatar
jman1
thanks... i did some searching and that vintage air system looks like the way to go..
Old Jul 30, 2011 | 09:26 PM
bryanpl123's Avatar
bryanpl123
This could get you started with the Stock install
I listed it in the F/S section
http://forums.corvetteforum.com/c3-p...em-1975-a.html
Old Jul 31, 2011 | 08:27 AM
Hodge's Avatar
Hodge
Just bought a Vintage Air setup for my 73. The kit arrived four days ago. Shipped to my door for $1370. That included an extra $50 for LS1 mounting brackets.
Old Jul 31, 2011 | 09:37 AM
Ganey's Avatar
Ganey
The main thing 75-76 factory air needs is a smaller lighter compressor instead of the heavy A6.
I replaced the R4 compressor with a ND 6P (8.2 C.I. & similiar to Sanden 508 used in Vintage Air) which uses less HP & works great. Compressor, custom brackets & hoses to stock A/C system.
Factory air has both fresh & recirculate.
Old Jul 31, 2011 | 11:37 AM
Manuel Azevedo's Avatar
Manuel Azevedo
If you don't mind saying, who did you buy it from? Sounds like a fair deal.
Old Aug 3, 2011 | 03:07 AM
Korevette's Avatar
Korevette
There are two systems in 1976. the long compresser for early and then the small unit for late. Now with that being said you still require a A/C unit.
Either go with a scrapped car with all of the plenums, hoses, console, evaporator, Receiver drier, A/C box, condensor, compressor and brackets for overhaul or an after market supplier.
To Add AC?
