torque spec for motor mounts?
Old Aug 17, 2011 | 02:05 PM
another-user's Avatar
another-user
Default torque spec for motor mounts?
ive got 3 different manuals, and none of them list the torque specs for a 69 small block. sure, they may all say to torque to spec, but none of them give that spec.
Old Aug 17, 2011 | 03:09 PM
7T1vette's Avatar
7T1vette
Just 'Google' "SAE bolt torque specifications" and look up the size and grade bolt used. If they are 3/8-16 bolts, 32 ft-lbs will do fine; if they are 7/16-14, 40 ft-lbs will work.
Old Aug 17, 2011 | 06:16 PM
Alan 71's Avatar
Alan 71
Hi au,
The 71 AIM indicates 22-30 lbs ft for the bolts that fasten the mount to the block, and 25-35 lb ft for the large bolt that fastens the mount to the frame bracket.
Regards,
Alan
To torque spec for motor mounts?
