Interior cockpit lighting
Old Sep 6, 2011 | 03:11 PM
GlennT73's Avatar
GlennT73
Default Interior cockpit lighting
For some reason my interior lights will not turn off. I've checked the door jamb switches on both doors and they seem fine. Any thoughts?
GlennT73
Old Sep 6, 2011 | 03:17 PM
Mashman's Avatar
Mashman
Is the rheostat on the headlight switch turned to the locked/on position?
Old Sep 6, 2011 | 03:19 PM
MelWff's Avatar
MelWff
have you made sure the headlight switch is not turned to the on position for the interior lights? Do you have separate switches for alarm and lights and are you checking the light switch?
GlennT73's Avatar
GlennT73
No I checked to make sure it was not stuck in the on position
Old Sep 6, 2011 | 03:21 PM
dembo's Avatar
dembo
Is the door actually pushing the switch pin in ? Did you try pushing them in by hand on both sides at the same time?
Might be a stupid remark,
Nick
Old Sep 6, 2011 | 03:29 PM
GlennT73's Avatar
GlennT73
Yes, Had my son help me push in both sides at the same time. Still no change. Lights stay on. The only way I can get them to go off is to disconnect the battery.
Old Sep 6, 2011 | 03:40 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
What year? Later cars have a timer which leaves the lights on for a while after you leave the car.
Old Sep 6, 2011 | 03:42 PM
GlennT73's Avatar
GlennT73
Its a 1973 vette. I thought the same thing, however the lights stay on continually and after a couple of days the battery goes dead.
Old Sep 6, 2011 | 03:56 PM
Alan 71's Avatar
Alan 71
Hi Glenn,
Still the obvious... does your car have a 'door ajar' warning light? If it does you'll have four switches, the interior lights are the switches on the hinge pillar, not the lock pillar.
Regards,
Alan
Old Sep 6, 2011 | 04:02 PM
C6DuffMan's Avatar
C6DuffMan
Sometimes the little bumpers for the switches move or fall off.
Old Sep 6, 2011 | 04:29 PM
GlennT73's Avatar
GlennT73
This is very helpful information. Thank you so much. I actually thought the switches were just the opposite. I'll go back and check the hinge side switches to see if they are both working properly. They both move in and out freely so maybe a wire came disconnected.
Old Sep 6, 2011 | 06:01 PM
GlennT73's Avatar
GlennT73
Okay so I pulled out both switches on the hindge pillars and the one on the drivers side has a hot and neutral wire, 1-black &1- white, but the passenger side only has one neutral wire/white. Should there be two wires on both switches??
Old Sep 6, 2011 | 06:12 PM
...Roger...'s Avatar
...Roger...
No your wires are right. The black on the drivers door side is for the key buzzer.
Old Sep 6, 2011 | 06:18 PM
GlennT73's Avatar
GlennT73
Thanks Rog, now I'm totally lost
Old Sep 6, 2011 | 06:26 PM
...Roger...
Grounding the white wires turns on your courtesy lights, so if one of those white wires is grounded the lights will stay on. For instance , if the white wire at the light in the cargo area is grounded the lights will come on. Happy hunting.
Old Sep 6, 2011 | 06:31 PM
GlennT73's Avatar
GlennT73
Thank you sir. Okay now I guess I have a bit more hunting to do. Really appreciate your assistance.
Old Sep 6, 2011 | 06:35 PM
...Roger...
Usually the first ting I do is unplug the 12 wire rear body connector in the drivers kick pad area,that will rule out the cargo light.
To Interior cockpit lighting
Old Sep 6, 2011 | 07:34 PM
7T1vette's Avatar
7T1vette
Did you try depressing the [newly found] correct switches to see if the lights go off? As someone else mentioned, there are some rubber 'bumpers' that stick on the mating part of the door and actually make contact with those switches. If one of the bumpers fell off, the lights would stay on.
Old Sep 6, 2011 | 07:41 PM
ctroadster's Avatar
ctroadster
ya know, I had the opposite problem with my interior light door switches where they wouldnt go on when the door opened. I moved the plunger on the switch in and out by hand and that didnt work. I had power to the switch. I took and rotated the plunger about 90 degrees and whala, it worked. Its been working ever since
Old Jul 24, 2025 | 09:19 PM
DomJD86's Avatar
DomJD86
GlennT73
Check that your courtesy lights on both sides are secured to their respective metal brackets. Losing the ground path will cause this
