C3 power window switch troubleshooting
Old Sep 25, 2011 | 02:12 PM
Hef's Avatar
Hef
Default C3 power window switch troubleshooting
I just finished up troubleshooting my drivers side power window problem.
The window would go down, but not up - occasionally it would engage up but the problem has steadily gotten worse.
I removed the side panels exposing the window switches.
Removed the switch and did a continuity test from the +12V terminal to each side of the switch. I discovered that one side of the switch had about 1.5 ohms of resistance with the switch engaged, and the other side had .5 ohms of resistance with the switch engaged.
After disassembling the switch I discovered that the contacts on one side were corroded and pitted. These cleaned up nicely with a small file. The resistance was rechecked and verified to be .5 ohms on both sides of the switch.
A deoxit spray was applied to the terminals and the switch was reassembled.
The window now works perfect and I saved about 30 dollars for a new switch.
Time will tell how long the repair works.
If you are in a bind and need a quick fix this is doable.
Old Sep 25, 2011 | 08:45 PM
7T1vette's Avatar
7T1vette
You have performed the repair in the best available method. The only thing I would have suggested you do differently is to use dielectric grease, rather than a [thinner] spray.
The original switches are much better quality than the aftermarket units. They have lasted 40 years and, as you have noted, the contacts were only corroded/lightly burnt and will still clean up nicely. Most aftermarket unit will only last a couple of years without some further trouble. For those who have bought aftermarket switches and have yet to install them, you can improve the life of those new switches by putting some dielectric grease on the contacts (if you feel comfortable doing a disassembly/reassembly of the switch).
The primary mode of failure for the stock switch is that the contacts will blacken/corrode/burn and generate a resistance layer than needs to be removed. Repairing them as you have done will allow those switches to last at least 100 years of servicible life.
Old Sep 26, 2011 | 07:55 PM
Hef's Avatar
Hef
Thanks for the feedback you obviously have some experience with the failure modes on these parts.
Its good to know that the stock parts are better than the aftermarket parts. I do agree with the dielectric grease idea, wish I had done that.
Another issue with the repair that I didnt mention is that the tabs that you bend in to secure the circuit board become fatigued as metal will, and one of them broke on me.
This is bad, as it allows the circuit board to flex down with the pressure applied by the switch, reducing the contact force and subsequent poor connection.
I ended up squeezing in the housing gently to secure the board, and I used some JB weld in the corners to ensure the circuit board will not move.
Hopefully you are right about the 100 years!
Hef
Old Sep 27, 2011 | 01:25 AM
7T1vette's Avatar
7T1vette
Yes. Sometimes, you have to get 'creative' with repairs to old parts. But as long as the repair is effective and secure, there is no harm done. Hey, the alternative is worse, IMO.
Old Sep 27, 2011 | 08:58 AM
jdp6000's Avatar
jdp6000
Hef
I also found that the new ones lasted about a year. In the end I did what you did. Opened and cleaned up the original. Put it back in, that was 4 years ago and all is good. I don't know what the difference is between the two but the new ones don't seem to last. To add insult to injury I bought my new switch from GM for $90 Delco box but made in China.....what has the world come to!!!!
I do the same for just about all the original parts. I'll try to fix them first.
Old Sep 27, 2011 | 11:03 AM
Hef's Avatar
Hef
I prefer fixing over replacement as its generally cheaper and if you do it right you get good results. Fortunately this forum is available to help us do it yourselfers.
I am currently struggling with rebuilding my calipers for the front.
The passenger front worked but the drivers side front is still leaking after 2 consecutive rebuilds.
All of the pistons have some level of pitting, and one has a tiny little nick in the top edge of the bore.
I am planning on removal and taking another look to determine which piston/bore is leaking, and go from there.
Old Sep 27, 2011 | 11:21 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
If your calipers are not stainless steel sleeved, I wouldn't bother rebuilding them as they generally don't last. If this is the case, opt for a set of SS ones as they can be reliably rebuilt again and again.
Old Sep 27, 2011 | 02:10 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
There should be plenty of material to stake over with a screwdriver and hammer along each side of the housing when the tabs break off. Hopefully one would have a good vise to clamp it in.
Also, pay attention when disassembling. If you put the guts back in 180* off the switch will work opposite I had to pull one back out and open it up again! One switch pushed forward would open, the other would close.
I've been suggesting this repair for years but it seems everyone just wants to buy a new one
To C3 power window switch troubleshooting
