Fuel Pump Mounting
Old Oct 12, 2011 | 09:49 PM
biscuitville's Avatar
biscuitville
Default Fuel Pump Mounting
I am considering the installation of an electric fuel pump and was wondering, where do people typically mount them on a C-3?
Old Oct 12, 2011 | 09:58 PM
A88FXRS's Avatar
A88FXRS
Typical location is along pass side frame where steel lines run.
Old Oct 13, 2011 | 03:40 AM
boltnut's Avatar
boltnut
It needs to push, not pull. Nearest the gas tank as practical and of course lower than the tank. I believe ideal race location would also be just behind the tank as well....
.....that is only if you don't want to to the trouble of an in tank pump.
Old Oct 13, 2011 | 10:01 PM
biscuitville
Thanks guys for the replies. I noticed there would be room for it on the top or outside of the passenger side frame rail, but thought that this could be a dangerous location if in an accident.
Has anyone fabricated a means of mounting a pump in the space for the spare tire?
Old Oct 13, 2011 | 10:45 PM
Ray Y's Avatar
Ray Y
Yes, it makes a nice set up if you don't mind giving up a spare tire.
Tank is sumped, Holley electric fuel pump, FRAM filter, shut off valve:
Instead of spare tire since I have 18" fat tires, I carry a tire repair kit from SLIME that has a compressor, bottle of SLIME, & plug kit:
And it buttons up with everything out of sight:
Old Oct 13, 2011 | 10:58 PM
72LS1Vette's Avatar
72LS1Vette
Here is another variation if you get rid of the spare tire. I ran a new fuel line down the driver side for the LS engine but you could just turn everything around if you were using the stock fuel lines.
Rick B.
Old Oct 14, 2011 | 08:25 AM
69 Chevy's Avatar
69 Chevy
...where do people typically mount them on a C-3?
I don't know about typical, but I found inside of the right rear frame rail was most practical place to mount my Summit G1507 fuel filter and Carter Universal Rotary Vane Electric Fuel Pump GP4594.
Old Oct 14, 2011 | 06:47 PM
biscuitville
Huge thanks guys! The pics gave me inspiration.
Old Oct 17, 2011 | 12:44 AM
jordan89's Avatar
jordan89
Good thing you asked this question. I just picked up an electric fuel pump and am going to install it in about three weeks.
Old Oct 18, 2011 | 02:29 PM
tekvette's Avatar
tekvette
here's mine
Old Oct 20, 2011 | 10:13 PM
biscuitville
Nice looking setup Tekvette!
Old Oct 20, 2011 | 11:34 PM
7T1vette's Avatar
7T1vette
If I installed an electric fuel pump, I would want it mounted to the inside of one of the side frame rails...in an area that would be most protected from a crash impact. Also, I would install hard fuel line from the pump to the carb, with a very short section of high pressure, braided line [between pump and carb] to absorb any chassis vibrations.
Old Oct 21, 2011 | 07:34 AM
biscuitville
I am loving all the great feedback. This may be one of the few projects I actually take my time on and get right the first time.
I was thinking I would make use of the hard fuel line.
Question for 7T1 (or others): why would putting it on a side frame rail be safer than where Tekvette has his? I thought the exhaust would be too close. Or do you mean on a side frame rail in the middle of the car?
I was considering doing a combination of what all three poster's pics are showing - installing it as central and forward as possible, and then making use of the spare tire cover for additional protection.
Old Oct 21, 2011 | 09:40 AM
7T1vette's Avatar
7T1vette
The exhaust isn't near the side frame rails except near the engine and toward the rear of the car. But, you knew that already, right?
To be more 'generic' about my previous response: Attach the fuel pump to something solid/sturdy that could take a hit without collapsing and on the side of that structure which would be 'away' from any external collision. Also, keep it far enough away from exhaust manifold/headers/downpipes to limit the amount of heat in the vicinity of the pump should it ever get damaged to the point of leaking or spraying fuel.
Does that help?
To Fuel Pump Mounting
