Ammeter Gauge
Old Oct 17, 2011 | 01:25 PM
50oldgeezer's Avatar
50oldgeezer
3rd Gear
Default Ammeter Gauge
I'm new to corvettes and have purchased a 1973/454. I've had problems with the starter not kicking in. I've had the alternator checked, and replaced the battery. What concerns me is when I do get is started, the ammeter gauge does not move. Granted, this gauge might be faulty, but assuming the gauge is working, about where should the needle be if the system is charging the battery? It seems it should be about half way between 0 and +40. thanks!
Old Oct 17, 2011 | 01:59 PM
694speed350's Avatar
694speed350
My 69 will jump up to +40a after starting and will taper back to just above 0 after driving a short distance.
Old Oct 17, 2011 | 02:06 PM
Peterbuilt's Avatar
Peterbuilt
Yes the battery gauge should go to the + side after first starting the car then is should come back to just a hair on the plus side as the battery recharges.
To bench test the gauge :
Connect ground to top post and just touch 12 volts to bottom post-neddle should deflect to minus.
Connect ground to bottom post and just touch 12 volts to top post-needle should now go to plus.
Starter not kicking in-clean all battery cable connections and see if that helps.
Old Oct 17, 2011 | 03:15 PM
50oldgeezer
3rd Gear
Thanks! I don't recall my gauge moving at all when I'm starting, but I'll check again. If the gauge doesn't move, then next step is the bench test.
Old Oct 17, 2011 | 04:02 PM
jnb5101's Avatar
jnb5101
just turn on the headlights. if the gauge and wiring is ok, it will deflect to the minus. but more than likely, it's the gauge. roger made a post showing (to my amazement) how tough these meters are, but i still managed to fry one!
Old Oct 17, 2011 | 05:43 PM
joewill's Avatar
joewill
your gauge will not move much while cranking, but after the engine starts and you rev it to about 1500 rpm, it should point significantly to the right for a few minutes. also your gauge should show movement as you tax the electrical system, headlights, high beams, wipers, horn.. all should cause your needle to move right if your engine is not running but ingnition is on. if this does not happen then something is wrong, bad gauge, or bad wiring..
i had the same problem and when i did troubleshooting, then I found that the genius previous owner plugged in the water temperature plug into the ammeter.
Old Oct 18, 2011 | 02:04 PM
Rally68's Avatar
Rally68
Check the condition of this fusible link at the firewall.
My understanding is this link protects the ammeter shunt. I would also recommend doing a forum search, there is quite a lot of good information about the function of the ammeter
Old Oct 18, 2011 | 04:52 PM
50oldgeezer
3rd Gear
I've heard that on some cars of this era that the ammeter was in 'series' with the battery and if the ammeter did not work, the battery would not get charged. Wonder if that might be the case here. Sorry guys..but I was a Mopar man up until I decided I wanted a 'vette! LOL
Old Oct 18, 2011 | 11:22 PM
7T1vette's Avatar
7T1vette
The ammeter is not wired "in series" with the battery. That would cause all of the vehicle's electrical current to run through the ammeter. It doesn't.
To Ammeter Gauge
