Solid or hydrolic lifters? 327ci
Old Jan 17, 2012 | 03:35 PM
  #61
DRIVESHAFT's Avatar
DRIVESHAFT
Originally Posted by TheDucci
I adjusted all the valves cold for a hydrolic motor and it fired right up and idled great. I then ran the motor and adjusted them all hot.
Your just a glutton for punishment, aren't you?
After the cold adjustment success, my valve covers would have stayed on the engine.
Old Jan 17, 2012 | 03:40 PM
  #62
TheDucci's Avatar
TheDucci
I hear you on that but after all I have been through why do it half way. On the cold adjustment I had one valve that was loud and I was probably half-an-half on being right on and too tight on adjustment for the rest. So it was worth it.
Old Jan 18, 2012 | 04:16 PM
  #63
Jims66's Avatar
Jims66
Ok, so it’s been awhile and I just got around to adjusting the valves this last weekend. After all the going back and forth with solid or hydrolic I adjusted all the valves cold for a hydrolic motor and it fired right up and idled great. I then ran the motor and adjusted them all hot. Everything seams fine and the motor is running great with the exception of a still wanting to idle around 950/1000 rpm but that’s for later.
Thanks for all the help.
Ya know, you may have an aftermarket cam in there which could be bigger than what came stock which may be why you can't get the idle down where you think it should be on a 250HP small block. That is if you're sure there's no vacume leak anywhere..... Just my 2cents here....
