Frustrating Blower Fan Problem
The blower has not worked since I got the car back on the road about a year ago. Looking at the diagram below-- there is no power on Point A (Blower resistor) or Point C (Heater Switch). There is also no continutiy between those two points. I can sometimes get continuity between Point B (Fuxe Box) and Point C (Heater Switch), but never between Point A (Blower Resistor) and Point B (Fuze Box).
Examining the fuze box carefully, the terminal for the fuze the side of the circuit disintegrated. I must conclude that the fuze connector has corroded and the wires have come disconnected behind the fuze block.
Fist question: Is there anyway to get to the back of the fuze block and make repairs -- I dont see how it would be possible unless one removed the wiring harness so that you could move the block.
So--- I decided to make a new circuit around the fuze block. Ran a 12AWG wire from the battery through a fuze, to point C (Heater switch) through the fire wall to Point B (Blower resistor). (Did anyone figure out what I did wrong?) Thats right!! The blower circuit has to be switched by the ignition because it is always on. I did prove that this fixes the problem, the blower works fine in all positions, exept for never turning off.
Question 2: How do I find a switched power souce that can handle 25Amps. Since the hot side of the fuze panel still seems ok, I will try to take it from there, but shoving a spade lug into the fuze box seems just to Bubba. (I realize this whole approach has a whole lot of bubba about it, but I cant see any other approach that does not remove the dash and wiring harness)
Sorry that it is so complicated, but any ideas would be appreciated
If the time and $ for that solution is too much ATM, you could put a relay & fuse at [51] that draws + from the hot side of the starter or alternator. Feed the blower switch across the switched side of the relay :
Bypass fuse at [50] with inline coupler
85 - connect to inline fuse A side
- connect inline fuse B side to [51] feed from Function Control Switch
86 - connect to ground
30 - connect to starter or alternator hot
87 - connect to [51] feed to blower switch
Mark
