Tachometer Cable Broken...
Old Jan 15, 2012 | 01:54 AM
Luke in SA's Avatar
Luke in SA
Default Tachometer Cable Broken...
Hi,
I was just out for a drive today when I looked down and the tach has stopped working.
Unscrewed the cable off my original points dissy when I got home and sure enough, it's broken about 2 inches along the cable.
Are these a PITA to fit a new one ??
Or -
Do you think I should retro fit some sort of electronic distributor & tacho ?
Go aftermarket cable HEI dissy ?
Just buy a new cable and wait another 43 years for it to fail ?
I'm sure this has happened to many a forum member.
It's a 68 SB.
Cheers, Luke.
Cheers, Luke.
Old Jan 15, 2012 | 04:13 AM
7T1vette's Avatar
7T1vette
If the problem is only the cable, it is an easy fix. But, before installing a new one, you need to pull the tach driven gear gizmo out of the dizzy and check its condition. There is a worm gear built onto the tach drive shaft and that brass cable connector should just 'screw' out of the housing so you can take a look at it. Check condition of worm and driven gear; also see if there are brass shavings in there that would indicate some damage to the driven gear (the worm gear on the shaft is hardened steel and should be OK in any event). The end of that driven gear may have dug into the inside of the dizzy case, also. That would need to be repaired so that the running clearance for that gear set will be maintained.
If you find a lot of shavings in there, it would be best to remove the dist. and disassemble to clean, check thoroughly, and do any needed repairs before reassembly. All those parts are replaceable and available.
If you find no shavings, stick a blob of white lithium grease on the tach driven gear, reassemble to the tach body, and hook up a new cable. It should be fine....unless there is some [odd] binding problem in the tach gauge, itself. You can always hook the new cable up to the tach head first and turn the cable with your fingers to see if any binding is present, before you hook it up to the distributor.
Old Jan 15, 2012 | 10:03 AM
69 Chevy's Avatar
69 Chevy
Originally Posted by Luke in SA
...it's broken about 2 inches along the cable.
Are these a PITA to fit a new one ?? Yes, as you'll need to remove the broken off cable before inserting the new one. That will probably mean you'll need to disconnect the sheath from the tachometer head behind the dash...a very crowed area. I would not use white lithium grease to lube the new cable. Use the proper graphite impregnated oil.
Just buy a new cable and wait another 43 years for it to fail ? Yes. Buy a universal speedo cable and cut to fit. Same quality yet less expensive than ordering a '68 tach cable from a resto supplier.
Happy motoring for the next 4 decades.
Old Jan 15, 2012 | 10:24 AM
Alan 71's Avatar
Alan 71
Hi Luke,
Since you mention it broke about 2" in/along it's length, you might want to check the position of the distributor to see if in setting the timing, it's been turned so far as to put a 'kink' in the cable near the distributor.
Checking that might prevent the cable problem from occuring again.
Good Luck!
Regards,
Alan
Old Jan 15, 2012 | 10:38 AM
7T1vette's Avatar
7T1vette
You may need to re-clock the distributor to get a straighter run on the cable (if you can make adequate distributor movement to adjust the timing) or install a right-angle cable adapter. Too tight a bend is bad for cable life.
Old Jan 15, 2012 | 11:16 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...Do you think I should retro fit some sort of electronic distributor & tacho?...
Why?
...Go aftermarket cable HEI dissy?...
Why?
...Just buy a new cable and wait another 43 years for it to fail?...
Bingo.
Old Jan 15, 2012 | 05:24 PM
Luke in SA's Avatar
Luke in SA
Thanks for your help/comments guys.
I might just grab another cable and replace it.
As Alan suggested, I should turn the dissy around a bit more as it does have a nasty curve in the cable.
Maybe the old points dissy can keep on going for a while longer yet.
Off to Willcox for a new cable...
Cheers, Luke.
To Tachometer Cable Broken...
