Temperature switch question.
Old Jan 17, 2012 | 08:50 PM
Dobbies's Avatar
Dobbies
Navigator
Default Temperature switch question.
I have a 1972 LS 5. On the drivers side between the 1st and 3rd cylinder spark plug, appears to be a temeprature switch. Since my temperature guage doesn't work and nothing is hooked up to the apprent switch, what does hook up to it? There is a wire with a female plug that extends from the alternator wiring harness, is this the wire that hooks up to the temperature switch? Thank you.
Old Jan 17, 2012 | 09:16 PM
speedreed8's Avatar
speedreed8
is it a dark green colored wire?
Old Jan 17, 2012 | 09:45 PM
Dobbies's Avatar
Dobbies
Navigator
It is thank you for asking....
Old Jan 17, 2012 | 10:10 PM
Dobbies's Avatar
Dobbies
Navigator
Any suggestions what it is or where it gets connected?
Old Jan 17, 2012 | 11:19 PM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
the wire connects to the male end of the temperature sensor in the block as you described. As stated, I think its green and may even have a heat sheathing around it.
Old Jan 17, 2012 | 11:28 PM
Dobbies's Avatar
Dobbies
Navigator
It does have heat sheeting around it and I thank you very much for helping me with the issue.
Old Jan 17, 2012 | 11:44 PM
7T1vette's Avatar
7T1vette
That temp sensor/sender should have just one pin on it. On the right hand cylinder head, between cyl #6 & #8 is the TCS temp switch which has two 'spade' pins. This is part of the TCS system and is used to turn that system ON or OFF depending on engine temp. (OFF if temp too low or too high; ON if in the normal operating range between those two OFF temps)
Old Jan 18, 2012 | 07:46 AM
71scgc's Avatar
71scgc
Go to the Willcox site, read and apply the test procedures for the temp gauge while the wire is disconnected.
Just sayin'...
Old Jan 18, 2012 | 10:56 AM
Dobbies's Avatar
Dobbies
Navigator
The 454 has two TCS ports, one on the drivers side and one on the passenger side....for whatever reason. The one on the passenger side does have two prongs for a female hook up but the drivers side, on my engine anyway, doesn't have that. I looked at the one on the drivers side again and the center of the TCS plug is missing so that probably is the single port hook up. I am going to get another one....I will also look at the Wilcox site for the testing procedures mentioned. Thanks all for your help.
Old Jan 18, 2012 | 12:09 PM
7T1vette's Avatar
7T1vette
For whatever reason, someone may have switched those sensors in the past. The temp gauge sensor wire is dark green [as mentioned above] and should be part of the alternator wiring harness. The sensor wire should have a single 'female' bayonet connector that would slide onto the [round] pin on the temp sender mounted between cyl #1 & #3.
Old Jan 18, 2012 | 12:39 PM
Mike Ward's Avatar
Mike Ward
This sounds correct to me as-is. The drivers side temp sender is for gauge indication only AFAIK, hence the single connection.
Old Jan 18, 2012 | 03:15 PM
Alan 71's Avatar
Alan 71
Hi,
I wouldn't say.... "2 TCS ports".
The sending unit in the left head is for the temperature gauge only.
The sending unit in the right hand head is part of the 72 TCS, and is a thermal switch with 3 positions:
1: engine cold; not up to operating temperatures.
2: engine with-in normal operating temperatures.
3: engine is above normal operating temperatures.
The only way I learned this was by studying up on the CEC and TCS systems in order to get mine to function. A REAL puzzle!
Regards,
Alan
Old Jan 18, 2012 | 09:35 PM
Dobbies's Avatar
Dobbies
Navigator
I purchased the round pin unit and will give it a try in the morning. Thanks all for the help it is much appreciated.
To Temperature switch question.
