Electrical problems
Hit a bump the other day and the brake light in the tach came on. Is this light for the emergency brake only? Doesn't seem to affect the brake tail lights
Problem two, Amp gauge doen't work. Never has since I got the car two years ago. Checked the fuseable link at the horn relay and that seems ok. When I pull apart the dash on the passenger side I will check the two post on the gauge to see if there is current. Also what does the little transistor on the back of the gauge do? And is it needed if I buy a new gauge?
Any helpful ideas???
Usually, one of the [internal] tie-off wires is 'fried' because of some overcurrent condition in the past. You can replace the meter or you can fix it. Up to you....
The "BRAKE" lamp could have gone on because of a couple of reasons:
1. The little switch in the e-brake housing failed at the same time (or because) you hit the bump;
2. The shuttle valve in the Proportioning valve somehow got stuck in a position where the light came on. Is it possible that either the front or rear section of the brake system got damaged when you hit that bump? If so, it would trigger that valve to shut off the 'defective' section and cause the warning light to come on.
The ammeter is connected through the body connector to 12V at the horn relay and the starter cable. Both wires to it will be 12V. Check the body connector for corrosion. A simple touch of a 1.5 V battery across the terminals will deflect the gage if it is good.
I have no idea what you mean by Transistor. There is a resistor on the back of the gage.
i've been told that you can reset the valve by a hard braking. before you try this though it's best for confirmation, so does anyone know if this is true? if true this is only a fix if you have no actual problems with the brakes such as air in the lines.
