Serpentine Belt Conversion
Old Mar 1, 2012 | 02:52 PM
Marlin's Avatar
Marlin
Originally Posted by vettehardt
I would like to know if there is a serp system out there that will allow you to use a stock 73 water pump and mechanical fan. I would be able to switch to a serp system, but my racing class mandates i must keep the stock water pump and must have the mechanical fan. I can change out pulleys and brackets, but not the equipment. Oh yea, i must keep the stock power steering pump also. Any ideas?
Have you asked what they consider stock? Could be they mean no electric pump.
A serp belt system from a late 80's GM truck could work. The pump will look the same just be a little differant height and they use a mech fan.
Old Mar 1, 2012 | 02:54 PM
Marlin's Avatar
Marlin
Originally Posted by wnmech
My 89 camaro water pump came with a port for the heater core and the other heater core port came off of the intake manifold.
Yea some do and some don't.
All the reverse alum. ones I see don't have any as the F-Body's did not need them. I'm going to go by advance and see if the one they stock has it or not.
Old Mar 1, 2012 | 03:02 PM
wan2run's Avatar
wan2run
I believe the truck systems may cause the accessories or tensioner to not fit below the stock hood.
Old Mar 1, 2012 | 09:51 PM
vettehardt's Avatar
vettehardt
Stock means came from the factory on a car in my class. I can update and back date between the years in my class, so that is from 63-82. **Edit: Meant to say any Corvette from 63-82 with the low horsepower motors** Any equipment run in those years I can run. FYI I run class 2 C/D in NCCC autocrossing.
I do not have AC and the heater core is bypassed. All i need the belt to go around is the crank, water pump, alternator and power steering pump. I must keep the engine driven fan. I am allowed to run an electric fan in addition to the mech fan, but that really doesn't cool the car any better.
Old Jun 28, 2021 | 06:10 PM
dannyboy70's Avatar
dannyboy70
1st Gear
Default Upper rad hose
Hello,
Can you tell me what make/model upper rad hose you have? I've been trying to locate a good fit for my 81 . Thanks
Old Jun 29, 2021 | 12:33 PM
Kidster71's Avatar
Kidster71
Highway Man
Originally Posted by dannyboy70
Hello,
I would like to know the make and model of that upper rad hose as well?
Cheers,
Richard
Old Jun 29, 2021 | 12:39 PM
speedreed8's Avatar
speedreed8
You guys do realize that pic is from 9 yrs ago.
doubt you’ll get a response.
Old Jun 29, 2021 | 12:43 PM
Kidster71's Avatar
Kidster71
Highway Man
Hello,
Damn, I fell for it! A resurrected old thread. We just had a discussion in another thread about this exact topic...
Old Jun 29, 2021 | 09:18 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Don't worry about it.....in the next month someone else will be doing the "Serp-Swap".
Now......I'ma scroll down and see how old the "related thread" is.
Update: "no relations".
Old Jun 30, 2021 | 06:09 AM
theandies's Avatar
theandies
Originally Posted by 68/70Vette
I have the GM Performance Parts Catalog Serpentine kit on my ZZ4 which is in my 68.
For a serpentine system for your C3, this is by far the most economical.
For extra bucks, toss the Serpentine kit cast iron water pump for an Edelbrock aluminum pump and get some March under drive pulleys.
Got a part number. I run a ZZ4 and now that my Fiero seat project is done I have to think of something else to do. Will it work with a spreader bar?
Old Jun 30, 2021 | 11:19 AM
TX427C3's Avatar
TX427C3
Active Streak: 90 Days
St. Jude Donor '06-'09,'22,'25
Considering wnmech hasn't been on the forum in six years I highly doubt you'll get an answer after nine years! LOL
Old Jun 30, 2021 | 12:19 PM
djquik1's Avatar
djquik1
Originally Posted by MyRed69
I decided NOT to go with the GMPP serpentine for my '69 due to someone at the local Chevy dealership writing in the parts catalog in big letters "will not fit under the stock corvette hood." I went with and '84 '89 combo setup. I still need to figure out an AIR pump delete.
It is the same set up used by several on here. It is the F body kit from 89-92
Old Jun 30, 2021 | 12:31 PM
  #33
Richard Daugird's Avatar
Richard Daugird
A spreader bar will fit. I am doing the swap with the serpentine from a 1995 Chevy truck. I'll start a thread when it's finished.
Old Jun 30, 2021 | 03:53 PM
  #34
vettebuyer6369's Avatar
vettebuyer6369
