upgrade L48
Old Apr 1, 2012 | 08:36 PM
scottyp99's Avatar
scottyp99
http://www.popularhotrodding.com/eng...s/viewall.html
http://www.popularhotrodding.com/eng...g/viewall.html
http://www.squidoo.com/How-To-Port-Cylinder-Heads
http://65corvette.nonethewiser.net/t...al/diyport.pdf
Keep the shiny side up!
Scott
Old Apr 1, 2012 | 08:49 PM
ghpeebles's Avatar
ghpeebles
Originally Posted by Dino_'72
As mentioned above. There is a difference between factory gross and net HP numbers.
L48 rated at 185 HP is the probably net mid '70s rating when it was really smogged and choked.
1970 L48 10:1s Gross HP -300
1971 L48 8.5:1 Gross HP -270
1972 L48 8.5:1 Net HP - 200
The 1971 and 1972 L48s are virtually the same engine. Only difference is on how the engines were rated.
There is potential in the L48, don't get put off by the net smogged 185 rating, you can liven it up.
Generally most talk HP in gross numbers. Net or rear wheel much better indicator, but more variables involved.
my vette is a 1978 l48..pretty tame
Old Apr 1, 2012 | 08:56 PM
ghpeebles's Avatar
ghpeebles
all smog junk is gone...has true duals
Old Apr 1, 2012 | 09:13 PM
scottyp99's Avatar
scottyp99
Are you sure they are not false duals?
Scott
Old Apr 1, 2012 | 09:23 PM
ghpeebles's Avatar
ghpeebles
Scott
absolutely true duals....had them put on!!
Old Apr 1, 2012 | 10:51 PM
billla's Avatar
billla
St. Jude Donor '14
Originally Posted by 7t9l82
the L-82 cam is the same as the 350/350 cam except it is retarded 4 degrees.
Still looking forward to any documentation at all regarding this claim regarding cam GM P/N 3896962 as used in the L-46 and L-82
Originally Posted by billla
There's 3 ways that come to mind that would document the cam installed retarded; either the cam/timing gears were different, or the cam was installed with different-than standard positioning of the cam/crank sprockets. The first two would generate alternate part numbers, the latter would be clearly documented in the factory service manual - fair? I would think anyone making this claim could do a little research and easily and quickly find out how (and if) this was done using standard and readily-available references
Old Apr 1, 2012 | 11:16 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Originally Posted by Tim H
I would say even if your engine only has 8.5 compression that those heads will detonate with any timing.
I would recommend some .041 thick Felpro head gaskets to help out some.
Otherwise go for it!
I have to totally disagree with this post. Your L48 has 8.2 to 1 compression. The L82 had 9 to 1 with horrible quench, about .065. If you add the 64 cc heads and a thin gasket .015 (felpro 1094) you can bump your L48 compression up to about 9.4 to 1 with .040 quench. These are the L82 cam specs. 3896962 Hyd. Advertised Duration 312/312, Duration @ .050 222/222, Lift I/E .450"/.460" LSA 114. This same cam was run in the L46 engine with Iron heads and 11 to 1 compression. The L82 cam will run fine with that much compression especially with tight quench. The slow factory ramps close the intake valve much later than a typical 222 duration @ .050 cam so zero detonation issues even with a performance distributor curve. With the performer intake, true dual exhaust I would guess 325HP. Your 650 is fine. Headers will help a lot. The L82 dynoed in this test @ 313 HP. Add performer intake, headers and an extra 1/2 point of compression your close to 350 HP.
http://www.superchevy.com/technical/...g/viewall.html
Old Apr 1, 2012 | 11:24 PM
billla's Avatar
billla
St. Jude Donor '14
A casting number on the heads would help a bunch, along with the valve sizes. The heads may be a wash with what you have; the compression boost (about a point) will help a bit, but not much.
Make sure you measure valve clearances and geometry with the change.
Old Apr 2, 2012 | 08:34 AM
ghpeebles's Avatar
ghpeebles
I'm not looking for 350 hp, just 275-300. If this setup gets that I'll be happy. Might add headers later. Thanks
Old Apr 2, 2012 | 08:39 AM
63mako's Avatar
63mako
The heads, intake and L82 cam will get you to 275-300. Go with the felpro 1094 gasket if your block hasn't been decked. Good quench has lots of benefits.
Old Apr 2, 2012 | 08:45 AM
ghpeebles's Avatar
ghpeebles
even if the heads have been shaved .10--.15, use the felpro 1094 gasket?
Old Apr 2, 2012 | 12:04 PM
billla's Avatar
billla
St. Jude Donor '14
Kinda surprised at some of the estimates here being given for a completely unknown set of truck heads. Unless they're something special, I'd expect around 275-300 HP - the configuration is basically a GMPP 350/290 crate.
Note that the Super Chevy results were with an electric water pump, no alternator, dyno headers and open exhaust...so take that number with a grain of salt...or even a whole salt lick
No mention of the (in) famous 4 degrees of retard with the L-82 in the article...
Old Apr 2, 2012 | 01:26 PM
  #33
MacVette86's Avatar
MacVette86
I have a 1977 L48 that has the original cam, heads and QJet carb. It has an Edelbrock Performer intake, long tube headers and dual exhaust (no cats). It dynoed at 191 HP and 251 TQ at the wheels. If you assume a 25% drive train loss due to the TH350, that would make it 239 HP and 314 TQ Net numbers. So yes, the L48 can be "livened up" quite easily.
[IMG][/IMG]
Old Apr 2, 2012 | 01:54 PM
  #34
63mako's Avatar
63mako
Figure the heads have to be as good as the factory L82 heads, The flow numbers on them are not very good even with the 2.02 valves. yes there are many ways to rate HP. As Super Chevy did on an engine dyno (gross), with accessories as installed in the car and factory exhaust (net)and RWHP(chassis dyno). I was talking Gross. He is between the L82 and L46 specs with as good or better intake. A performance dist curve is a big help too. The 290 HP crate is 8.5 to 1 comp so I would think he can do better than that and the L82. 350 HP is too optimistic.
Old Apr 2, 2012 | 01:58 PM
  #35
billla's Avatar
billla
St. Jude Donor '14
How can we figure that with zero information on the heads?
I agree with the apples-and-oranges thing regarding measurements - I just wanted to ensure we were all on the same page regarding what that HP number represented.
I guess I'm just overly careful on these "how much power will it make" threads
Old Apr 2, 2012 | 02:37 PM
  #36
scottyp99's Avatar
scottyp99
I just want to make sure you know that the heads you have are not the vortec heads that everybody talks about. Until we see a casting number, we can't really be sure what you have there, but there were some heads on TBI motors from that era that had what they called a "swirl port", which I guess worked pretty well at very low rpm, for torque, (valuable in a pickup truck) but which are pretty restrictive at higher rpm. There are several guys on this forum who can give you a lot more, and better, info than I can, but they need a casting number, so dig one up as soon as you can, OK?
Scott
Old Apr 2, 2012 | 03:20 PM
  #37
nate99's Avatar
nate99
I was just searching on the 3896962 cam was in the 290hp crate engine that I have and was going to poke around and see what heads might go better with that than the iron 76cc heads that it came with.
I have many bridges to cross before I get there, but it's interesting to see that folks are getting entirely decent numbers out of what I felt was a compromise engine on my part.
I still have dreams of a 383 (or a big block) down the road. I may save up for that and sell the 290 and not bother with upgrading what I have.
To upgrade L48
Old Apr 2, 2012 | 04:13 PM
  #38
ghpeebles's Avatar
ghpeebles
that's about the hp I wanted....close to 290-300
Old Apr 2, 2012 | 06:48 PM
  #39
ghpeebles's Avatar
ghpeebles
1987 --- 14101083----milled .10--.15
Old Apr 2, 2012 | 08:09 PM
  #40
7t9l82's Avatar
7t9l82
exactly the way most crate motors are rated.
