upgrade L48
Old Apr 1, 2012 | 02:34 PM
ghpeebles's Avatar
ghpeebles
Default upgrade L48
putting 64cc cast iron heads, L82 cam and edlebrook performance intake on the engine. how much will I increase the hp? all parts were free so don't tell me to go buy this or that.
Old Apr 1, 2012 | 03:37 PM
Mark Riles's Avatar
Mark Riles
Just off the hip I'm guessing around 275 HP if the carb is tuned and your timing is done right.
Old Apr 1, 2012 | 04:10 PM
Tim H's Avatar
Tim H
I would say even if your engine only has 8.5 compression that those heads will detonate with any timing.
I would recommend some .041 thick Felpro head gaskets to help out some.
Otherwise go for it!
Old Apr 1, 2012 | 04:41 PM
ghpeebles's Avatar
ghpeebles
it also has a 650 holley
Old Apr 1, 2012 | 04:45 PM
ghpeebles's Avatar
ghpeebles
it has a 650 holley
Old Apr 1, 2012 | 04:46 PM
scottyp99's Avatar
scottyp99
What kind of 64cc cast iron heads, and what kind of edlebrook performance intake?
Keep the shiny side up!
Scott
Old Apr 1, 2012 | 04:55 PM
ghpeebles's Avatar
ghpeebles
it has a 650 holley
Old Apr 1, 2012 | 04:59 PM
ghpeebles's Avatar
ghpeebles
Scott
low rise performer with 650 holley
Old Apr 1, 2012 | 05:01 PM
ghpeebles's Avatar
ghpeebles
1987 64cc truck heads
Old Apr 1, 2012 | 05:19 PM
ghpeebles's Avatar
ghpeebles
Default L48 upgrade
putting on 1987 64cc cast iron truck heads, L82 cam, low rise edlebrook performer alum. intake with a 650 holly carb....what hp should I get. parts are free so???
Old Apr 1, 2012 | 05:57 PM
7t9l82's Avatar
7t9l82
here we go again. the N.H.R.A rated the L-82. at 300+ horsepower. you have less compression and cam. small chamber heads will give you compression, close to 9.5-1 . the L-82 cam is the same as the 350/350 cam except it is retarded 4 degrees. with that cam advanced 4 degrees and the heads with a thin gasket you will have north of 300 horsepower. that will be a nice package with a manifold headers and the ignition set up correctly.go for it. there were thousands of motors built with the 350/350 cam that was a great street cam and still is
Old Apr 1, 2012 | 06:00 PM
scottyp99's Avatar
scottyp99
What you are doing sounds very similar to the GM Performance 290 horsepower crate engine, with a little more compression. With cast iron manifolds, I would have to agree with Mark.
Scott
Old Apr 1, 2012 | 06:07 PM
Dino_'72's Avatar
Dino_'72
Guessing around 300 to 315.
I think L48 was available in 1970,and it had 10:1 compression with the .390/.410 lift cam. Also this cam was rated at 195 degrees duration at .050. Very small cam. Factory spec'd this engine at 300 HP.
Going with 64 cc heads will yield you about 9.3:1 compression with fish pistons. Shim gasket maybe 9.5:1. Plus if theses heads off a truck are vortecs, they will flow much better than old camel humps.
This coupled with more agressive L82 should yield higher HP than a stock 1970 L48. If factory figures can be relied on.
I know you said not to comment on parts, but if I could I would go with another cam. I always found the L82 cam to be a little lazy on the bottem end. Just my comment. For small $$$ you could get a better cam.
Good luck
Old Apr 1, 2012 | 06:57 PM
Mike Ward's Avatar
Mike Ward
The guess of 275-300HP are gross rating, meaning maybe 220-240 net. Pretty tame stuff.
Old Apr 1, 2012 | 07:30 PM
ghpeebles's Avatar
ghpeebles
thanks for the comments....keep them coming!!
Old Apr 1, 2012 | 07:35 PM
ghpeebles's Avatar
ghpeebles
they are not vortec heads!
Old Apr 1, 2012 | 07:41 PM
ghpeebles's Avatar
ghpeebles
the l48 only has 185 hp...that;s pretty tame stuff !!!
To upgrade L48
Old Apr 1, 2012 | 07:52 PM
ghpeebles's Avatar
ghpeebles
the heads have been shaved maybe .15
Old Apr 1, 2012 | 07:55 PM
7t9l82's Avatar
7t9l82
as a cam gets more radical the low end gets weaker generally. its a good combo for the investment. and those net figures factored in the lousy exhaust system a set of headers and a good exhaust do wonders for those numbers. do some bowl work on the heads that will help too
Old Apr 1, 2012 | 08:03 PM
Dino_'72's Avatar
Dino_'72
As mentioned above. There is a difference between factory gross and net HP numbers.
L48 rated at 185 HP is the probably net mid '70s rating when it was really smogged and choked.
1970 L48 10:1s Gross HP -300
1971 L48 8.5:1 Gross HP -270
1972 L48 8.5:1 Net HP - 200
The 1971 and 1972 L48s are virtually the same engine. Only difference is on how the engines were rated.
There is potential in the L48, don't get put off by the net smogged 185 rating, you can liven it up.
Generally most talk HP in gross numbers. Net or rear wheel much better indicator, but more variables involved.
