Cracked piston...$^*#@!!!
Old Apr 8, 2012 | 10:16 PM
billla's Avatar
billla
St. Jude Donor '14
Curious - how do the others look? Did you measure the piston/bore/ring gap/etc.?
Old Apr 8, 2012 | 11:24 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Good catch, u saved your engine.
Originally Posted by resdoggie
Here are some pics. The cracks are just inside the black marker lines.
http://forums.corvetteforum.com/album.php?albumid=25340
Wow, just in time as that engines life was nearly over. A broken piston can turn a block into scrap in a second. Curious though it makes me wonder too if the valves somehow struck the pistons dome or detonation from too hi c.r.. As long as its out now u could try and polish out the cracks to see how deep they are.
Regardless of your replacement choice u need to match piston weights.
Great effort,
cardo0
Old Apr 9, 2012 | 06:25 PM
Surfer69's Avatar
Surfer69
Also curious, did your engine burn excessive oil by any chance?
Old Apr 10, 2012 | 06:42 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Originally Posted by billla
Yeah, I think that needs to be checked. It's a darned odd crack, though...
Showed the piston to a guy at work who knows engines. He has never seen cracks in a piston like this. He also examined other areas of the piston and didn't find any areas with abnormal wear or dings, scratches.
Originally Posted by 63mako
Pull the piston and have it checked. It looks like a crack to me also. If it is cracked don't buy another KB POS and replace it. You got what you paid for. Buy some good low expansion forged pistons and redo it....Rebalance, bearings, rings. at a minimum. That sucks!
It will be forged next time. I have a deal on 7 KB slugs!
The others are still in their holes but they look fine. No cracks or any other signs of wear or interference. The cylinder wall is scored in #4 that had the cracked piston but the piston isn't giving away any secrets as to how this occurred. The block will need to be bored so the all the pistons will need to be replaced. 383, here I come!
Great effort,
cardo0
Yeah, I got lucky for once!
Nope. It was running normal. No oil burning. Car was running strong.
My guy at work couldn't see any telltale signs of detonation which is what I was suspect of to cause the cracks. I think I will contact KB and send them the pics and the piston if they want to analyze it. Warranty is long over but it may help them out if cracking is rare for this type of piston.
Old Apr 11, 2012 | 02:29 PM
cardo0's Avatar
cardo0
Default Thank u for sharing this.
I'm sure we would all like to hear the response from KB - if u get the chance.
Good luck with the re-ring,
cardo0
Old Apr 11, 2012 | 09:11 PM
Solid LT1's Avatar
Solid LT1
cardo0
KB isn't around anymore. Now selling under Icon brand and funny thing they brought out a whole line of FORGED pistons over 10 years ago......
Old Apr 13, 2012 | 04:25 PM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
Default Update
I emailed KB regarding the (unusual) cracks in the piston. Here is their response:
Mike,
Have not seen a crown crack like this. We may get a better idea if we saw
the piston. You can send it to the address below to my attention. We will
have to cut it into sections to better look at the cracks.
A single may be available. Forward the gram weight for the piston and pin
only, part number and oversize.
Best regards,
Marko
United Engine & Machine - Icon - KB Performance - Silvolite - KB VTwin
Motorcycle
1040 Corbett St.
Carson City, NV 89706
I made it clear to KB that I was not seeking any warranty (17 years later and 15K miles) but just wanted to know if they could determine the cause so I could take steps to prevent this from happening again. I'll have the piston in the mail next week. I'll let you all know the results when KB gets back to me.
Old Apr 13, 2012 | 05:16 PM
billla's Avatar
billla
St. Jude Donor '14
I have to admit it makes me feel better that I'm not the only one that thinks it's an odd crack.
Old Apr 13, 2012 | 06:04 PM
ezobens's Avatar
ezobens
Wild.. Not at all what I expected to see.
With where the cracks are, it almost looks like on either side of the rod?
If this were a marine engine, I'd say hydro-lock but in a street engine, no clue...
Old Apr 13, 2012 | 09:01 PM
mike76c3's Avatar
mike76c3
Default What were the results of your tests?
Did they indicate how deep the cracks are? I'm curious because they're relatively parallel -- almost like something was in there and maybe scratched the surface. Did you ever use something to try to find TDC in that cylinder, or stick something else in there? Or maybe they got slightly scratched before installation, and the scratch shows up better after all this time and wear?
Mike
Old Apr 14, 2012 | 10:55 PM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
Mike
They don't have the piston yet. I did use the business end of a hammer to get it into the cylinder J/K. AFAIK the piston was fine when I put it in 17 years ago.
Old Apr 14, 2012 | 11:33 PM
cardo0's Avatar
cardo0
Mike,
Best regards,
Marko
Motorcycle
1040 Corbett St.
OK so KB pistons may have been sold but still supported by new parent company. Thanks for correcting a previous misleading post stating "KB isn't around anymore". That and somehow the KB forged line has something to do with your issue with a hyper piston is just mud and distortion.
Well i hope to read of results from KB. I think we all need/can use the education here.
Thx for the updates resdoggie,
cardo0
Old Apr 26, 2012 | 07:27 AM
  #33
resdoggie's Avatar
resdoggie
Royal Canadian Navy
Default Final update
I took the piston to a local automotive machine shop last week to remove the pressed in pin so I could ship the piston sans rod to KB for their analysis. The local shop inspected the piston and said it was definitely a scratch. They also said that hyper pistons don't crack - they break, period. Alright, so I had a dye penetrant test done. Negative results. It was also put under a microscope and it clearly showed that they were scratches. Well, it sure looked like a crack. The good news is I can put it back in the engine for another season. Next year I will pull the engine and put in a 383 stroker rotating assembly.
Old Apr 26, 2012 | 07:36 AM
  #34
bashcraft's Avatar
bashcraft
Originally Posted by bashcraft
Chances are what you're seeing isn't a crack. A piston cracked like you describe would've already come apart. It's not difficult to take it out, so go ahead and have a shop check it out before you decide to replace it.
What do I win?
Old Apr 26, 2012 | 09:38 AM
  #35
hugie82's Avatar
hugie82
Good call Bash! I never seen a scratch look like that? The way it fades into a thin line then disappears. I wouldn't feel confident in those slugs but I'm a wiseco guy
Old Apr 26, 2012 | 02:07 PM
  #36
cardo0's Avatar
cardo0
Default Thatt'a boy Bash.
Wow, do pictures lie or what? Good news for resdoggie and thx for posting all this. Just hone, re-ring and brg now?
Man this turned out to be a pretty cool thread on pistons,
cardo0
Old Apr 26, 2012 | 06:51 PM
  #37
resdoggie's Avatar
resdoggie
Royal Canadian Navy
What do I win?
Nothing. But you get a pat on the back for nailing it on the head!
To Cracked piston...$^*#@!!!
Old Apr 26, 2012 | 08:59 PM
  #38
OMF's Avatar
OMF
I just went back and looked at your pics again. Now that we know they are only scratches on the piston, I assume you used clay on this piston to check for your piston to valve clearance.....and then sliced the clay down the middle to measure your clearance after peeling half of the clay away.......did I guess right?
Old Apr 27, 2012 | 11:40 AM
  #39
Ben Lurkin's Avatar
Ben Lurkin
St. Jude Donor '09
Originally Posted by RIO68
Had two KB"s crack out at the top ring groove and I fixed it with 8 new forged pistons! Problem solved---like others have said pic's would be good to see what it looks like.
That's usually because they weren't gapped correctly. Hypers in general and KB's in particular need a much larger top ring end gap.
Interesting thread.
Old Apr 27, 2012 | 05:04 PM
  #40
resdoggie's Avatar
resdoggie
Royal Canadian Navy
There was no piston-valve interference. The engine has been running for +15K miles.
