Cracked piston...$^*#@!!!
Old Apr 7, 2012 | 08:18 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Default Cracked piston...$^*#@!!!
While progressing with my top end rebuild I started to clean the small amount of carbon off the top of my KB hyper pistons. On closer inspection of #4, I noticed a hairline crack just to the left of centre in the exhaust valve relief about an 1.5" long. Then I see a shorter hairline crack across the intake valve relief. My finger nail just barely catches when I run it across the crack. So, it's toast! Is there anything preventing the removal of the piston while the engine remains in the car? The car is on jackstands and I don't want to remove the block which I know is a better way to do it.
Old Apr 7, 2012 | 08:49 AM
Mark Riles's Avatar
Mark Riles
Can of worms. Technically all you have to do is rotate the crank so you have access to the piston rod cap to remove the fasteners, remove the cap, and push the piston up and out through the top of the bore. So technically, not much is keeping you from changing the piston. You have to be very careful though that the bearing nor journal are altered or damaged and you can re-use them when the piston is replaced and the rod is reinstalled in the block. This isn't a perfect world, and it's not that easy unless you can find that exact same part number piston. Unless you get the exact same piston you'll need to change all of the pistons using this same method and that puts you back to the best option of removing the block and doing it right.
Old Apr 7, 2012 | 09:09 AM
bashcraft's Avatar
bashcraft
Chances are what you're seeing isn't a crack. A piston cracked like you describe would've already come apart. It's not difficult to take it out, so go ahead and have a shop check it out before you decide to replace it.
Old Apr 7, 2012 | 09:20 AM
69 Chevy's Avatar
69 Chevy
Depending on how many miles are on your engine, there could be a ridge at the top of the cylinder that needs to be removed before you push out the piston. Most of the big box auto parts stores will lend you this 'ridge reamer.'
Old Apr 7, 2012 | 10:13 AM
cv67's Avatar
cv67
St. Jude Donor '05
Id think if it would have come apart being a hyper.
Got any pics of it? Sure its not a scratch?
Somtimes castings will have some funny looking stuff on them that can really throw you off.
Get some pics up see what Carl has to say
Old Apr 7, 2012 | 10:36 AM
billla's Avatar
billla
St. Jude Donor '14
That would be my take as well.
A picture might be worth a thousand words here before you take the next step.
Old Apr 7, 2012 | 10:53 AM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
Great input! Thanks lads. I too was kinda miffed that if it was a crack then why hadn't the piston grenaded. I assembled this engine myself many years ago (maybe 15K miles on it now) but don't recall any "scratches" on any of the pistons but who knows. I'll take it out and have it examined. Maybe get it x-rayed at my work! A replacement piston can still be had from KB with the same specs for about $65 from Jeg's if I need to replace it.
Old Apr 7, 2012 | 11:06 AM
birdsmith's Avatar
birdsmith
Get a couple pieces of fuel hose or similar material and push it up onto the rod bolts after you've removed the rod cap...if the threaded part of either rod bolt even lightly taps the crank journal it will leave a mark, so you need some protection on there when removing the piston/rod assembly. From the way you're describing it though that sounds more like a typical casting imperfection; I'd make absolutely sure before I pulled that piston out of the hole.
Old Apr 7, 2012 | 11:21 AM
TimAT's Avatar
TimAT
Before you rip the pan off and do all the work to get that piston out, think about getting a Spotcheck kit:
http://www.grainger.com/Grainger/SPO...26-128580020-2
That will prove there's a crack or a casting flaw.
Old Apr 7, 2012 | 11:28 AM
birdsmith's Avatar
birdsmith
What he said...if you can blend that thing smooth with some cartridge roll-type sanding barrels or a mounted stone and then do a liquid penetrant test on it that would tell you what you've really got...just make sure you get ALL of the debris out of there before you button it all back up.
Old Apr 7, 2012 | 11:50 AM
DRIVESHAFT's Avatar
DRIVESHAFT
X3. A penetrant test will tell you for sure if there is any surface cracking - no piston removal required.
resdoggie's Avatar
resdoggie
Royal Canadian Navy
I'm replacing the base pan gasket anyway so I will remove the piston. It's no big deal at this point. I'll have the guys at work do their NDT magic. Then there will be no doubt as to the integrity of the piston and I save $87 for a dye penetrant kit! Another option is to get a 383 rotating assembly
Old Apr 7, 2012 | 01:34 PM
birdsmith's Avatar
birdsmith
Well now, if you've got NDT equipment at work, why not get a little bit of penetrant and some developer and save yourself all that work and the risk of nicking the crank or breaking a ring? Just do it on the car...just a thought.
Old Apr 7, 2012 | 03:03 PM
jackson's Avatar
jackson
heck ... if crack's IN the eyebrows ... perhaps the valves kissed the eyebrows.
good pics (not cellphone) might help here ... a lot.
Old Apr 7, 2012 | 10:00 PM
RIO68's Avatar
RIO68
Had two KB"s crack out at the top ring groove and I fixed it with 8 new forged pistons! Problem solved---like others have said pic's would be good to see what it looks like.
Old Apr 8, 2012 | 10:14 AM
bashcraft's Avatar
bashcraft
That happens when the rings aren't gapped properly.
Old Apr 8, 2012 | 03:04 PM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
Here are some pics. The cracks are just inside the black marker lines.
http://forums.corvetteforum.com/album.php?albumid=25340
To Cracked piston...$^*#@!!!
Old Apr 8, 2012 | 03:54 PM
zwede's Avatar
zwede
That doesn't look good. Time for some forged puppies!
Old Apr 8, 2012 | 10:06 PM
billla's Avatar
billla
St. Jude Donor '14
Yeah, I think that needs to be checked. It's a darned odd crack, though...
Old Apr 8, 2012 | 10:15 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Pull the piston and have it checked. It looks like a crack to me also. If it is cracked don't buy another KB POS and replace it. You got what you paid for. Buy some good low expansion forged pistons and redo it....Rebalance, bearings, rings. at a minimum. That sucks!
