I read that the 70-72 Corvettes were very underpowered due to emissions. What did they do to decrease the horsepower? Just wondering if it would be something that would easily be reversed. And if there is a thread or link to this that would be great!
The catalytic converters of the day did flow very well. Aftermarket ones today flow better so you won't get the power loss that you would with the original cat.
AIR pumps add drag to the engine so that can take away from power.
Keep in mind that in 1972 the measurement of HP went from gross to net. The numbers seem like less HP but that isn't always the case.
The difference in HP by removing that stuff is minimal. If you really want HP, get a C6. These cars are old technology and there are kids today with modified Hondas that will blow C3s and C4s away.
In 71 they reduced compression ratios because of emissions requirements. In 72 the horsepower was essentially the same but rated net (rather than gross). The real drops in performance actually came in 74-up. 75 was extremely low.
Thanks for the tip! I have college to get through before I can even start thinking about a vette but why not learn while I can? By the way, I really like your Stingray and Z06. Very clean!
The 1970 Corvette had some of the most powerful engines GM ever built. The emissions systems on the 70-72 Corvettes did not rob the engines of much power. In '71, the compression ratio lowered so that all GM engines could run on unleaded gasoline. In '72, the method of rating engine horsepower was changed to a "net" value (minus losses from attached engine 'accessories') instead of the "gross" HP method used previously. But, the engines in the '72 C3's were [essentially] identical to those in '71.
When at WOT, the emissions 'add-ons' had little impact on the engine's performance...other than the reduced compression ratio, which was required by GM. [And that can be easily altered with new heads.]
No Corvette prior to 1975 had a catalytic convertor. The much maligned AIR pump system uses a whopping 1 HP.
The actual decrease in HP was due to a combination of reduced compression ratio, milder cam and conservative ignition maps- all of which was required to meet smog regulation and to run on the brand new unleaded low octane gas.
The simultaneous change in how HP was advertised just added to the confusion and perception. Crate engines are still sold with gross HP ratings- the so-called 300HP engines area really about 225-250HP.
1970 was really the peak in terms of performance for American cars in the 'Musclecar era'. The enviro-**** crusade actually began in 1965 with minimal measures like PCV valves vs. open breather tubes, etc. but most 1970 cars still had minimal smog equipment. As Mike stated when low-lead gas was introduced in 1971 automakers had to reduce compression ratios to accomodate the new gasoline and by 1975 all new cars had to run unleaded gas which required low compression ratios along with catalytic converters.
I actually de-compressed my '70 from 10.25:1 down to 9.25:1 in order to get it to run without protest on modern swill...somewhat of a drastic measure and actually pulling it off turned out to be one of the biggest headaches of my entire life but in the end I'm glad I did it.
Our 1970 LT-1 Vette makes 370HP on 350 cu/in. I think that is a pretty good HP per cu/in rating. The 72 LT-1 was rated SAE net HP of 255 I think the 70 would be around 305-320HP tested in the same manner.
Hi,
Here are the published S.A.E. net numbers for the 1971 engines.
They really don't seem to be very widely known, and NOTE; they're different than the 1972 numbers.
Regards,
Alan
The base sb and bb engines are pleasant to work on because they didn't have the AIR equipment.
Not really much sense in comparing a pickup truck to a corvette.
Of course not! I just used an example of an older car. I know they are geared much much differently and don't hold ANYTHING to a Vette! Just wondering what the mpg of those extreme machines?
