top end speed
Old Apr 16, 2012 | 08:50 PM
Dblancha's Avatar
Dblancha
8th Gear
Originally Posted by gkull
I used a gear ratio calc. and depending on tire size you might have a 3.73 rear end.
You can change rear end gear or tire diameter, but then you might not have enough power to go any faster.
Thanks, I don't know what I have for gears. Will check it out
Old Apr 16, 2012 | 08:57 PM
Dblancha's Avatar
Dblancha
8th Gear
Originally Posted by scottyp99
The issue here is that you don't have an overdrive transmission. You're probably a young guy who is used to cars having overdrive, and may have a tough time understanding a car that doesn't have it, but that's how it was back in the before time........in the long, long ago. 1:1 in high gear was pretty much it. Cars with high top speeds had to either rev really high, or have a low numerical diff gear. Really fast cars had to have both, not a great combo for launching the car. Now, we have overdrive transmissions, and can enjoy the best of both worlds!
Keep the shiny side up!
Scott
Thanks for info.
Old Apr 16, 2012 | 10:14 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Yep, with a good run out of The Downhill you can see some real speed by the time you cross start/finish. If you do this sort of thing very often, you really might want to think about converting to an manual OD 5-speed. That said, aero is going to become a factor of the first order to get going very much faster, which will start requiring some real power, and if you don't already have them I'd seriously consider a front dam and rear spoiler to keep your shark grounded. My $.02
TSW
Old Apr 16, 2012 | 11:28 PM
briankeery's Avatar
briankeery
These are the Road & Track numbers:
1978
Engine L48
Transmission 3-Speed Auto.
Final Drive Ratio 3.08:1
0-30 mph (sec) 2.9
0-40 mph (sec) 4.2
0-50 mph (sec) 5.8
0-60 mph (sec) 7.8
0-70 mph (sec) 10.2
0-80 mph (sec) 13.3
0-90 mph (sec) 17.5
0-100 mph (sec) 33.1
1/4 Mile (sec/mph) 16.1 / 88.3
Top Speed(mph) 123
1979
0-60 mph (sec) 6.6
0-70 mph (sec) 8.6
0-80 mph (sec) 10.9
0-90 mph (sec) 13.7
0-100 mph (sec) 17.5
1/4 Mile (sec/mph) 15.3 / 95.0
Top Speed(mph) 127
Old Apr 16, 2012 | 11:31 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Originally Posted by 1979carl
I think that 6,000 rpm on an unmodified engine is pushing it. Lucky it stayed in one piece. In mine with 3:55 gears and a TH350 at 110 mph rpm's are 5500.
L82 should handle 6000 rpm with no problem for short bursts. Factory ratio with an auto was 3.55
Old Apr 17, 2012 | 01:03 AM
7T1vette's Avatar
7T1vette
gkull..
If you are going to 'pick' at what another poster says, at least have the courage to put in the whole quote. Otherwise, I'll just lump you in along with the swill of 'rag' newspaper people that editorialize and misstate what's been said by others.
You have a race car. It is set up for handling and high speeds. The OP probably has a 40 year old car, engine and suspension; and who knows what for tires. I care enough about his wellfare to offer a concern...and you chide him on to "go for it".
Old Apr 17, 2012 | 02:42 AM
Little Mouse's Avatar
Little Mouse
ajrothm jumps on his hayabusa runs a for real timed 227 mph in the texas mile on a friggen motorcycle and folks are worried a little over a 100 mph in there car lol.
Old Apr 17, 2012 | 07:47 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Originally Posted by ajrothm
I made a top speed run this past sat night(which is only slightly passed a 1/4 mile for me). At 6190rpm I was at 137mph (gps) and it was pretty much done...It hit 137 mph it about 3/8 of a mile...
Getting ready for the 1/2 mile race at Ellington in May?????
JIM
Old Apr 17, 2012 | 08:11 AM
gkull's Avatar
gkull
Originally Posted by 7T1vette
gkull..
You are correct about using safe speed rated tires. I made some assumptions. One is how many people take a crappy beater car to a road racing track when you have to pay $175 entry fees? Then any track I have ever been to has safety techical inspections before they let you loose on a higher speed road course.
Even take it another step. they have to complete some series of driving school classes before being allowed out on the full blown road racing track.
Old Apr 17, 2012 | 08:50 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
In 5th gear I will hit 110mph @ 2700rpm
What scares me and I did this too many years ago when I first got mine. Is I buy the car and the first thing I did was take it out on the highway and floor it, probably up to 100mph or so without taking it home first and checking everything. I found loose bolts etc all over the place I could have killed myself
Old Apr 17, 2012 | 09:49 AM
BKbroiler's Avatar
BKbroiler
Originally Posted by Lemans Blue 69
Why does my stock 1969, L46 with 3:70 rear and close ratio trans top out at 140 mph. Am I missing something with the newer vettes?
If you're doing 140 mph with 3.70 gears, your engine is at 6,500 rpm (assuming 27 inch tire dia.) Running at that rpm level long enough to reach top speed is quite a challenge.
Old Apr 17, 2012 | 09:56 AM
bashcraft's Avatar
bashcraft
Running at that rpm level with a stock L46 is probably not possible. At least not for more than a couple seconds.
Old Apr 17, 2012 | 01:33 PM
  #33
pauldana's Avatar
pauldana
When my 79 L-82 was stock I could reach near 130.. When built 140 was easy but ran out of RPM....
Got my tko600 in a week ago.... Had her up to 165mph and still had room to go... But the front end was getting light...... Next step is to put on 2 vents in the hood like Beejay did... He told me it really brought the front end down above 120...
Wanted to add... 1st 2nd 3rd and 4th make no strain on the engine, will rev to 6500 fast and effortlessly, 5th.... thats another story, ..... .64..... that get up and go,,,, just not like 1234... much slower acceleration.
Old Apr 17, 2012 | 04:04 PM
  #34
jnb5101's Avatar
jnb5101
one request:
all you guys that are talking 120, 140, 175mph-can i take out a life insurance policy on you? i could use some extra cash.
Old Apr 17, 2012 | 05:31 PM
  #35
ajrothm's Avatar
ajrothm
ATLEAST 6500...
Holding it at 6500 and above for an extended period with stock HYD lifters and springs is not likely..
I would have probably hit 140mph (gps) at 6400 IF my valve train, fuel system and everything else would have help up... I know I was either running out of fuel pressure or getting the beginning stages of valve float at 6200 in 3rd/hi gear. I'd need a solid roller and big fuel system to go any faster...And that is with only 3.36 gears and 28" tires. I do get a LOT of front end lift though so that's probably slowing me down some.
I have a hard time believing stock C3s are running 140+...a TRUE 140 anyway..
Old Apr 17, 2012 | 05:36 PM
  #36
ajrothm's Avatar
ajrothm
Lol.. Good point...
But going fast in 40yr old cars with 40 year old technology is a bit "interesting..".
I have been in the 180s in my Z06 and that was much scarier to me then going 225 on the bike..
Old Apr 17, 2012 | 05:39 PM
  #37
ajrothm's Avatar
ajrothm
JIM
No.. I thought about taking the Busa but it's $300 for track entry..that's pretty steep for only 1/2 mile racing. I think the Busa would run 210 in a half mile with the right gearing and boost control..
I am building my Z06 as we speak and it's costing a fortune. I can't afford to tear up any of the other toys..
I will be spectating at the Houston mile though.
To top end speed
Old Apr 17, 2012 | 07:25 PM
  #38
U17's Avatar
U17
I added a front spoiler on mine after the first time over 100mph...http://i237.photobucket.com/albums/f...8new/aero3.jpg
Old Apr 17, 2012 | 08:42 PM
  #39
Lemans Blue 69's Avatar
Lemans Blue 69
BKbroiler, bashcraft, ajthrom,
Ever drive a 1969 L46 stock and see what it can do. I own one and am the original owner. Yes, I'm 67 and purchased the car in February of 1970 brand new when I turned 25. The car did 139 mph back then with a passenger on board and it was at about 6000 rpms. Give a little maybe. Maybe the speedo lied a bit and maybe it didn't. Would cruise at 100 MPH with ease. Driving from Montreal to NYC on beautiful 87 got radar ed by a trooper. Ask how fast I was going and told him the truth. 100 mph. Gave me the ticket and thanked me for being honest for he just had his radar gizmo calibrated.
Like to hear from someone who owns or owned one like mine and not from those who have never driven one. It was a muscle car. Stock.
Old Apr 17, 2012 | 08:57 PM
  #40
BKbroiler's Avatar
BKbroiler
Lemans Blue 69,
I'm 61 years old and I remember all about the muscle car era, back when they were new. Simple mathematics haven't changed over the decades and 140 mph is 6,500 rpm. The only "guess" in that is tire diameter. I was being generous when I used 27 inch, your tires might actually be (or have been) smaller. I will assume speedometer error accounts for the discrepancy. The trooper's radar probably wasn't too accurate back then either.
