Washers as wheel spacers
Old Apr 23, 2012 | 12:12 PM
sstopczy's Avatar
sstopczy
Default Washers as wheel spacers
I just got new wheels and the rears are a little close to the sway bar so I would like to bump them out about 1/8" and thought the washers that were on the old lug nuts would be about the thickness I would need. This seems like a more balanced approach than some of the spacers I have seen that have large holes on one side and small holes on the other. I have a torque wrench to properly torque the lug nuts down and know I would need to check them regularly to make sure they are not coming loose at all. Is this a feasible solution or would my wheels fall off?
Old Apr 23, 2012 | 12:14 PM
MelWff's Avatar
MelWff
I woundnt do that the wheel has to be against the full hub or a suitable spacer.
Old Apr 23, 2012 | 01:05 PM
76stingracer's Avatar
76stingracer
I would also advise against this. For mock-up would be ok but once you find the correct spacer thickness go out and buy the correct spacers.
Old Apr 23, 2012 | 01:38 PM
scottyp99's Avatar
scottyp99
Hey, man, these guys are just being polite, that idea is just flat-out crazy! The forces involved are spread out along the mating surface of the wheel to the hub, washers will concentrate these forces, and that is a bad idea. A bad idea. I'm pretty sure they make 1/8" spacers, use them. Please.
Keep the shiny side up!
Scott
Old Apr 23, 2012 | 02:03 PM
Ben Lurkin's Avatar
Ben Lurkin
St. Jude Donor '09
That's a good way to lose a wheel and cause an accident.
Here's what you need:
http://www.summitracing.com/parts/GOR-SP601S/
Old Apr 23, 2012 | 02:13 PM
cv67's Avatar
cv67
St. Jude Donor '05
"Nothing but the best for MY baby"
sstopczy's Avatar
sstopczy
Thanks for all the input. I just ordered these.
Old Apr 24, 2012 | 07:41 AM
corvettedave383's Avatar
corvettedave383
The next problem you might have, if u still have the factory wheel studs, you will struggle to get enough lug nut encagement with spacers in there
Dave
Old Apr 24, 2012 | 08:04 AM
sstopczy's Avatar
sstopczy
Dave
I tried it with washers and there was plenty of stud for the nut so I think I will be alright.
Old Apr 24, 2012 | 02:17 PM
7T1vette's Avatar
7T1vette
"You picked a fine time to leave me Loose Wheel...."
[as sung by Darrell Waltrip]
To Washers as wheel spacers
