Adding a Bubba PCV ?
Old May 14, 2012 | 02:35 PM
Clams Canino's Avatar
Clams Canino
I went with a right angled one (PV781) - for an SBC. Here's the pic of my "Bubba PCV".
Remember the goal was only to stop underhood spatter from that breather cap - not actually cross-vent the block.
Note: Fuel filter setup is temp until I run a few tanks through it - it sat a LONG time.
I already changed that filter twice.
Click For Bigger Pic
Old May 14, 2012 | 04:38 PM
oldalaskaman's Avatar
oldalaskaman
ya gotta do, watcha gotta do
Old May 14, 2012 | 08:45 PM
scottyp99's Avatar
scottyp99
Well, ya did what you set out to do: learn a little about how a pcv valve works, and cobble up something that will solve a problem, even if just temporarily. Let us know how it works, OK?
I'm thinking that a more permanent solution might be to mount the pcv valve in a hole drilled in the back of the intake manifold, behind the carb. That way, you would get some ventilation. I imagine you'd have to figure out some way to keep it from sucking an excessive amount of oil, though, with all that oil splashing around in the lifter valley. Or, you could put a cap on the filler tube that would seal it, and have the air intake on the back of the manifold, going into the air cleaner. Either one would require removing the intake, though. Oh, well, I hope your Bubba pcv works out,
Keep the shiny side up!
Scott
Old May 14, 2012 | 10:48 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
http://www.bing.com/images/search?q=...AF8A0A&first=0
http://www.bing.com/images/search?q=...=0&FORM=IDFRIR
http://corvettespecialty.com/crankca...fitting-holley
This is how you do it. No PCV valve. This was the factory setup on a 65 vette with sealed valve covers. Keeps negative pressure on the crankcase and the fitting restricts the flow so it is not a vacuum leak.
Old May 14, 2012 | 11:12 PM
scottyp99's Avatar
scottyp99
How does the 1/8" fitting attach to the carb? Do you need to drill and tap a hole in the baseplate?
Scott
Old May 14, 2012 | 11:30 PM
63mako's Avatar
63mako
Scott
This is the setup I used on my tripower with additional breathers in each valvecover. The center carb baseplate had a hole in the rear of it that the fitting threaded into. I know the fitting is for a holley but I think many of the aftermarket carbs have a threaded hole there, maybe for the power brake booster?
Old May 15, 2012 | 07:51 AM
Clams Canino
While that would clearly work too, I had a fitting for a vacuum hose right at the front of the Q-jet, making this setup practically write itself.
If I ever pull the intake off, I'll try something with more cross-flow for sure.
I'm still amazed that this "temporary engine" is still in the car - life has a way of taking over.
I understood how PCV worked - I just never understood the exact function of the valve. Easy enough though.
-W
Old May 15, 2012 | 09:49 AM
7T1vette's Avatar
7T1vette
If the fitting on the front of the carb is NOT in the baseplate of the carb, that fitting is inappropriate for the PCV purge line. It is merely a 'manifold' or 'ported' vacuum source and has a very small orifice that won't flow enough air to get the job done.
And, you can't just drill a hole in the top of a breather cap and stick a PCV valve in it. Since the breather cap is vented, much of the blow-by would still exit the vents on the cap and still put oily air into your engine compartment. You could put a PCV valve into a sealed oil fill cap, as it is not vented. You need to construct the system as Lars and I have described, if you want it to work very well.
Old May 15, 2012 | 11:08 AM
Clams Canino
It's in the baseplate of the carb - so it's full manifold vacuum.
And I'm hoping that since I'm well under the breather cap (see pic) that it will scavenge most of the oily air in the tube.
I'll report back after some hours.
Let's remember that this car has 20 years on it with just the breather cap. I'm just trying to cut down (or eliminate) what little misting it had.
-W
Old May 15, 2012 | 11:55 AM
scottyp99's Avatar
scottyp99
this isn't an issue that has come up during this thread, but it is something that I would like to take the opportunity to address, as long as we are on the subject of crankcase ventilation. If you have a functioning PCV system, it is important that the air being pulled into the crankcase be filtered air, or the dust and grit will cause engine wear. Maybe not to the same extent as unfiltered fuel mixture air, but still, some.
Scott
Old May 15, 2012 | 12:12 PM
Clams Canino
Funny you said this.
Since I well know that more than 1/2 the air getting pulled into my intake port via the PCV valve will be coming through that breather cap - I just got a new one this morning that has plenty of "stuffing" in it. (My old one was really worn out)
-W
Old May 15, 2012 | 12:51 PM
scottyp99's Avatar
scottyp99
Ya know, now that I think about it, you may find that when you floor it, and manifold vacuum drops down near zero, and crankcase pressure rises, it may overpower the pcv valve, and you still get a little oil mist coming out of the breather. A sealed cap on the filler tube with a hose going to the inside of the air filter would ensure filtered air going through the pcv valve when it was operating, and any blow-by would be directed into the inside of the air filter, to be burned by the engine, instead of sprayed around your engine compartment. Might be kinda funny-looking, though!
Scott
Old May 15, 2012 | 01:01 PM
  #33
Clams Canino
It's already a little "funny looking".
I'll surely report back what (if any) blow-by escapes this kluge.
-W
Old May 16, 2012 | 09:32 PM
  #34
Clams Canino
Put about 50 miles on it in the last couple days - so far no blow-by oil escaping.
-W
Old May 17, 2012 | 03:54 PM
  #35
scottyp99's Avatar
scottyp99
-W
Well, I guess that's it for all the hypothetical stuff. You had a problem, you thought something up and tried it, and, so far anyway, it's working. 'nuff said!
Scott
Old May 17, 2012 | 04:21 PM
  #36
noonie's Avatar
noonie
Scott
Scott
Scott
Nothing hypothetical about any of that.
That's the way GM designed the pcv system to work.
Hard to re-engineer anything better.
Old May 24, 2012 | 10:55 PM
  #37
Clams Canino
OK - 300 miles. No mist - no nothing. Perfect!!!
-W
