Differential Oil Replacement
Old Oct 3, 2012 | 08:26 AM
  #41
7T1vette's Avatar
7T1vette
You use the 'fill' plug hole to suck it out; then you use it to add the new stuff until it just starts to run out that hole.
Old Oct 3, 2012 | 12:08 PM
  #42
tyancey00's Avatar
tyancey00
how often do you see yourself changing the rear end fluid?
Old Oct 3, 2012 | 12:29 PM
  #43
jim2527's Avatar
jim2527
Most people never change it....Because I dont beat the heck out of my car and it has stock-ish horsepower I'll make sure it's 'topped off' once or twice a year and change it every few years.
Differential and gear boxes are designed for long oil change intervals unlike engine oil.
Old Oct 3, 2012 | 12:33 PM
  #44
bouvie1's Avatar
bouvie1
Default Siphon/fill gear oil-additive
Originally Posted by Ralphbf
Passenger side, top rear, there is a plug.
Suck it out and fill through the plug hole.
R~
Ralph thanks for your advice and all other posts regarding this issue,bouvie 1
Old Oct 3, 2012 | 01:57 PM
  #45
Clams Canino's Avatar
Clams Canino
GM obviously didn't think people would change it - thus the lack of a drain plug.
-W
Old Oct 3, 2012 | 02:51 PM
  #46
Ralphbf's Avatar
Ralphbf
-W
On a side note.
I changed my oil, drove about 1000 miles and changed it again.
It was almost as dirty the 2nd time as the 1st.
There must of been a lot of stuff in the bottom that didn't get sucked out.
R~
Old Oct 3, 2012 | 08:27 PM
  #47
PeteZO6's Avatar
PeteZO6
I just had the diff fluid changed in my '07 ZO6. My factory Service Manual calls for diff fluid and friction modifier as most on this thread have stated. When I reviewed the work order, I noticed they didn't use any friction modifier, so I asked the service adviser about that. We went to the parts counter together and the parts man looked up the required fluid. Seems GM decided their newest diff lube doesn't need a friction modifier.
The oil (diff fluid) the dealer put in my ZO6 is GM #88862624. The Z takes almost 4 quarts @ suggested retail of $22.46/qt.!!
Remember these cars (since MY 2007) have a 5 year/100,000 mile power train warranty, so it is not likely that GM would spec. an inferior product when repair would be on their dime if the diff frags.
Just my 2¢.
Pete
Old Oct 3, 2012 | 08:38 PM
  #48
jb78L-82's Avatar
jb78L-82
Just my 2¢.
Pete
I have been saying that the newer synthetic gear oils do not need the additive for years!!! Try convincing the nay sayers that 30,40, 50 year old rear differentials that original were spec'd for an additive back then, now do not need the additive any longer with the synthetic gear oils. I have been using Mobil 1 75W-90 synthetic gear oil with no additive for 22 years with zero issues. Good luck with that!
Old Oct 3, 2012 | 10:58 PM
  #49
Clams Canino
CORRECT - The new Synthetics do NOT need the additive.
However, the stock lube DOES.
-W
Old Dec 23, 2016 | 01:39 PM
  #50
sakins.02vert's Avatar
sakins.02vert
Question on this.. I have no idea if the fluid in my rear end is GM or synthetic. What would you recommend I use to replace it?
Old Dec 24, 2016 | 06:51 AM
  #51
jim2527's Avatar
jim2527
Whatever the book calls for. No need to get fancy if your car is mostly stock.
Old May 9, 2018 | 09:22 AM
  #52
Primoz's Avatar
Primoz
2017 C3 of Year Finalist
What about us in Europe who can't get hands on AC Delco fluid? Which oil to put in our diffs?
Old May 10, 2018 | 02:04 PM
  #53
jb78L-82's Avatar
jb78L-82
See post #48. I use Mobil 1 75W-90 for over 20 years but have also used Amsoil. I trust Redline Gear oil as well. If none of those work, I would trust Castrol EU as well, if they have a synthetic.
Old May 10, 2018 | 02:54 PM
  #54
Primoz's Avatar
Primoz
I found this one in my country from Mobil 1!
http://www.motornaolja.com/produkt/m...-1-shc-75w-90/
Old May 10, 2018 | 02:59 PM
  #55
MelWff's Avatar
MelWff
the product says nothing about use in limited slip differentials
use this http://www.motornaolja.com/produkt/c...-slip-75w-140/
Old May 10, 2018 | 03:09 PM
  #56
Primoz's Avatar
Primoz
They also have this one:
https://www.motul.com/us/en-US/products/90-pa
Old May 10, 2018 | 03:12 PM
  #57
ddawson's Avatar
ddawson
Can you get Torco there?
http://www.torcousa.com/6-dealer/europe.html
To Differential Oil Replacement
Old May 10, 2018 | 03:24 PM
  #58
Primoz's Avatar
Primoz
Originally Posted by ddawson
I can actually!
Old May 10, 2018 | 03:27 PM
  #59
MelWff's Avatar
MelWff
use this one unless you can find a Torco 75w90 for LSD
https://www.motul.com/us/en-US/produ...r-300-ls-75w90
Old May 10, 2018 | 08:21 PM
  #60
fede's Avatar
fede
@Primo, here in Europe you can easily get Valvoline or Mobil 1 from ebay. Pay attention to the specific oil you are buying as Valvoline for example has many 75w90 gear oils but only 2 valid for limited slip differential:
https://www.valvolineeurope.com/engl...ducts/axle_oil
The Mobil 1 oil you found is not a differential oil and is not for limited slip, this is the correct one:
https://mobiloil.com/en/gear-lubrica...c-gear-lube-ls
