Differential Oil Replacement
Old May 10, 2018 | 09:03 PM
  #61
jb78L-82's Avatar
jb78L-82
Originally Posted by fede
@Primo, here in Europe you can easily get Valvoline or Mobil 1 from ebay. Pay attention to the specific oil you are buying as Valvoline for example has many 75w90 gear oils but only 2 valid for limited slip differential:
https://www.valvolineeurope.com/engl...ducts/axle_oil
The Mobil 1 oil you found is not a differential oil and is not for limited slip, this is the correct one:
https://mobiloil.com/en/gear-lubrica...c-gear-lube-ls
This ^^^^ is the Mobil 1 75W-90 Gear oil that I have used for 20+ years in the diff.....
Old Jun 7, 2018 | 10:12 AM
  #62
Primoz's Avatar
Primoz
2017 C3 of Year Finalist
Originally Posted by MelWff
use this one unless you can find a Torco 75w90 for LSD
https://www.motul.com/us/en-US/produ...r-300-ls-75w90
I will use this one! It is available with no problems and at good price!
