Avoiding Crossfire
May 16, 2012 | 09:43 PM
Avoiding Crossfire
On an HEI ignition in a 77 L48 which plug wires should NOT be run next to or adjoining to prevent crossfire?
The aim shows #2 and #3 routed around front of distributor.
What is a good way to route wires with only lower shields still on car
May 16, 2012 | 11:11 PM
Buy better quality plug wires...
May 16, 2012 | 11:59 PM
amen, good wire, dont have to worry bout it
May 17, 2012 | 01:22 AM
I'm using Taylor Spiro-pro and have had problems with radio noise and a "miss"
by running the #2  wires in front of the distributor I eliminated the radio noise but the "miss" still is there.
I've replaced the cap and rotor and all plugs (.045 gap)
wires are about 6 years old and have low mileage(15,000 miles)
May 17, 2012 | 07:09 AM
do a continuity check on the wires , then do a resistance check, and while you're doing the checks, shake the wires to simulate engine vibration.
May 17, 2012 | 07:10 AM
My first job Thursday morning........
May 17, 2012 | 09:27 AM
If they are 'rubber' wires, rubber deteriorates with time and heat. Put your car in a darkened garage at night, lift the hood and fire it up. You should be able to see any high-voltage leakages from those wires, if there are any. If so, change them to something that is good quality and won't break down so quickly.
May 17, 2012 | 11:26 AM
The wires are taylor spiro-pro...silicone.......
This morning I found 2 wires that were bad....
May 17, 2012 | 11:31 AM
May 17, 2012 | 12:16 PM
Corrected Cap
I use an ACCEL corrected cap. It allows you to rout the wires on the proper side without any crossing or touching. It also looks great.
Combine that with a decent set of 'cut to lengh' wires and a cheepee wire loom kit and your problem is solved for about $150.00
Find the cap here:
http://www.jegs.com/p/Accel/Accel-HE...03636/10002/-1
May 17, 2012 | 12:40 PM
St. Jude Donor '14
A long time ago, it was all about keeping wires apart. Look at racing engines today - heck, they zip-tie them together
May 17, 2012 | 12:58 PM
Want to avoid "crossfire?" Don't buy an '82 or '84.
May 17, 2012 | 12:59 PM
Quote:
Originally Posted by
toddalin
Ouch!!
May 17, 2012 | 01:59 PM
I'm replacing wires..............
hope that solves problem.........using MSD ........
I'll keep everyone interested posted.
May 17, 2012 | 08:09 PM
All this hating on my Crossfire, is going to make Baby Jesus cry!
May 17, 2012 | 08:25 PM
wires and broken valve spring were the cause of my issues.......
thanks to all for your information and advise.
