Can't shift at all
Old May 25, 2012 | 11:51 AM
mleejr's Avatar
mleejr
1st Gear
Default Can't shift at all
Just took my 69 out for a pretty hard run. Shifted with no problems. Got into fairly high speed and when I slowed down and got ready to downshift, could not move shifter at all. Was able to get home in fourth, but cannot budge it. Any ideas on what to do first. Have never had shifting issues.
Old May 25, 2012 | 12:13 PM
69 Chevy's Avatar
69 Chevy
Get it up in the air so you can crawl under to inspect the linkage.
Old May 25, 2012 | 04:45 PM
7T1vette's Avatar
7T1vette
You've got some shifter linkages bound up with each other. For that to happen, they have to be very loose. You likely need a new set of links and/or bushings to 'snug' that mechanism up a bit.
Old May 25, 2012 | 08:25 PM
JohnRR's Avatar
JohnRR
If you still have the sloppy Chevy shifter, then consider installing a Hurst. I did and it's an amazing improvement.
John
Old May 25, 2012 | 11:30 PM
Jclgodale3's Avatar
Jclgodale3
Yep...sounds like the classic shifter bind
To Can't shift at all
