Full manifold vac?
Old May 31, 2012 | 02:35 PM
ATIS's Avatar
ATIS
Default Full manifold vac?
Where is the full manifold vac ports on a Quadrajet at IDLE? (1975 L48, all original)
Are those the conenctions along the base or the ones higher up near the middle/top of the front of the carb?
I think I messed up my vac lines so I need to reverify all of them as being connected to the correct spot... my idle INCREASES as the car warms up which is backwards. LOL
Old May 31, 2012 | 04:06 PM
ATIS's Avatar
ATIS
lets make this easy, anyone have a diagram for the vac line connections on a 1975 Quadrajet without AC but with power brakes and steering?
Old May 31, 2012 | 04:33 PM
Mooser's Avatar
Mooser
Not sure when/if they changed but the early Q-jets only had the one ported vac line just by the idle adjustment screw, all the others were manifold vac.
HIH
Mooser
Old May 31, 2012 | 05:03 PM
ATIS's Avatar
ATIS
thanks, that would make the ported the one for the dist advance correct?
Old May 31, 2012 | 05:25 PM
Mooser's Avatar
Mooser
Properly, yes
But if you read through (mainly Lars' papers) if the advance unit meets certain criteria, the car may like full manifold vacuum on the advance.
I did mine (timing, carb, etc) last weekend and it does seem ok with full vac on the advance and although only two days (maybe 4 hours) driving, it is running cooler around town (go figure)
Mooser
Old May 31, 2012 | 05:52 PM
ATIS's Avatar
ATIS
My issue is I cant get the idle under control. Currently it is 800 on cold start and climbs to 1200 when warm! I must have put a vac line back in the wrong place on the carb so I am going to go back through them all.
Old May 31, 2012 | 07:23 PM
Jeff_Keryk's Avatar
Jeff_Keryk
On some later Q-Jets, look for a tube on the passenger side of the carb.
Old May 31, 2012 | 07:54 PM
ATIS's Avatar
ATIS
Will do. Its at the body shop, my flex fit bumper covers shifted some so they are being realigned! I have a show on saturday.
Old May 31, 2012 | 11:27 PM
7T1vette's Avatar
7T1vette
For 'testing' purposes, you need to pull off all vacuum lines feeding other systems and plug their outlets, so that you can set the carb up and determine if there is a carb problem or a vacuum leak somewhere. By plugging off all the possible leakage points (except for intake manifold and carb gaskets), pulling the hoses and plugging them off will limit possible leakage points to intake and carb gaskets. You can check for gasket leaks by shooting very small puffs of carb cleaner at potential leak areas (while the engine is idling) and listen for rpm increases [which would indicate that the carb cleaner is being ingested via that area of gasketing]. Check around carb base, along the sides of the intake manifold, and at the [valley] ends.
If you do this and are successful with getting the carb to idle well, then put the hoses back on and see what happens. Problem? It's in the vacuum system somewhere. No problem? High five!
Old Jun 1, 2012 | 08:18 AM
71scgc's Avatar
71scgc
The only manif. vac source I could find on my Q-jet was on the pass. side, coming out by the choke/fast idle cam. The carb is a service replacement. The correct number, date code carb I replaced it with does not have this port. I replaced the brake booster port with a part for a GTO with ram air. It has a small nipple on it that I hooked my dist. to for manif. vac. Check Dr. Rebuild catalog for vac. hose routing.
Somehow, I don't think your prob. is vac. related.
Make sure your fast idle cam isn't repositioning/hanging up in a higher idle setting. Might try a little lube in that area first, but I'm no expert...
Old Jun 1, 2012 | 08:40 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The Assembly Instruction Manual shows them.
Old Jun 1, 2012 | 11:13 AM
lars's Avatar
lars
On the 1975+ M4M (integral choke) Q-Jets used with the EGR systems, the only ported vacuum source is the nipple coming out of the carb throttle baseplate on the front passenger side corner at a 45-degree angle. All other ports are manifold vacuum. The ported source and the direct manifold vacuum ports were routed to a temperature control valve which "decided" which "type" of vacuum to route to the distributor and the EGR, depending on engine temperature: When the engine was dead cold, there was no vacuum at all to the distributor. This retarded timing heated the engine up quickly and lowered emissions. Once the engine got up to normal operating temp, the valve switched the distributor to ported vacuum to keep emissions low at idle, yet allow vacuum advance at cruise. If the engine got hot, the valve switched over to full manifold vacuum to advance the timing and cool the engine down. The EGR always ran off ported vacuum so that the EGR would stay closed at idle and only open at cruise.
If you eliminate the temperature valve, you can run the EGR right off the ported vacuum nipple and hook up vacuum advance to any of the other nipples, which will be manifold vacuum.
Lars
Old Jun 1, 2012 | 06:54 PM
Paul L's Avatar
Paul L
Lars
I learned something today. That is vastly different from my 1974 where most spouts are ported (I think) except the one near the choke assembly.
I do use ported vacuum for the distributor (again I think). In any case the car runs well and temps are normal. The carb is #7044206.
This is where I thought manifold vacuum is but I get no constant vacuum there. The rebuilder may have used a wrong base gasket. And given that the car runs well I am not going to fool about.
Old Jun 1, 2012 | 09:48 PM
ATIS's Avatar
ATIS
Thanks for the info eveyone. I get her back from the painter tomorrow (front cover shifted and chipped the edge so they repainted the entire front cover and it will be ready for pick up tomorrow at 9am... I have a show at 11 so it will be close if the weather holds out) then I will get back to fixing the idle issue.
To Full manifold vac?
