Project 69-LS3
Old Jun 25, 2012 | 04:09 PM
BB502's Avatar
BB502
Default Project 69-LS3
Hi,
Here is my new project, it´s a matching nr 1969 with a 300hp 350.
My plans for this car is a frame of restoration and mount a LS3 engine and a Tremec TKO trans.
My first job was to remove the body from the frame
I found this behind the instrument panel
I purchased a used LS3 from a Corvette 08 and a new Tremec TKO 600,
This is the first test with the LS3 and Tremec in the frame.
The normal problem with a LS engine...
After i have checked the fitting of the engine and trans i stripped the frame, and cut out the only part that was not ok on the frame and welded in a new plate.
The frame and all the other parts was sandblasted and a epoxyprimed
and painted semi gloss black.
All the bolts,nuts,washers and brackets was coated, this is a few of them.
Old Jun 25, 2012 | 04:53 PM
'75's Avatar
'75
Great job so far!
Old Jun 25, 2012 | 06:37 PM
BB502's Avatar
BB502
Thanks " ´75 "
I forgot to show this picture of the new pulley to the steering pump, there is no problem now with the pulley hitting the control arm. ( but i cut the bolt on the control arm , just for safety)
The pulley is a modified pulley from a Saab...
The frame is ready to be reassenbled again.
I made new brake lines:
The engine was painted chevy orange:
The control arms was rebuild with poly bushings:
I purchased a set of Coilovers:
The front end is almost finished:
I´m making my own version of the Steeriod rack and pinion kit ( the steering rack is from a Saab 9-3 ), mounted in brackets i have made:
I haven´t decided if i should go with these brakes (I must use 18" wheels or bigger ) or if i should use standard size brakes so i can use 15" rally wheels if i want to:
The engine is back in the frame again:
I made a bracket on the engineblock so i can use the original clutch likange:
This is so far i have come ( i´m from Sweden so you have to excuse the spelling...)
Old Jun 25, 2012 | 06:55 PM
DEEPSEA70's Avatar
DEEPSEA70
Default Saab pulley
How did you modify the pulley?
Old Jun 25, 2012 | 07:11 PM
Hadez's Avatar
Hadez
Are all home garages in Sweden this clean? Hell man..how do you even keep the pictures level on the wall.
Nice work
Old Jun 26, 2012 | 01:07 AM
uxojerry's Avatar
uxojerry
If you go with the Brembos,check out wheels from Billet specialties. They are designed to fit any of the big brake kit calipers. The big brake wheels are part of their pro-touring wheel collection. I havnt bought mine yet, but will in the next few weeks. I like their wheels because all I have to measure is the backspacing.
Old Jun 26, 2012 | 03:37 AM
BB502's Avatar
BB502
The pulley should normaly be mounted with three bolts and had a big center hole, so i made a new centerpiece and that piece was welded in to the pulleys center hole.
Old Jun 26, 2012 | 04:09 AM
BB502's Avatar
BB502
This is how the engine looks now:
I´m using the original manifolds, no problems with the clutch linkage.
Old Jun 26, 2012 | 06:39 AM
PatsLs1vette's Avatar
PatsLs1vette
Your doing an incredible job so far.
Old Jun 26, 2012 | 08:57 AM
Jasonb86's Avatar
Jasonb86
Beautiful job, incredible attention to detail and very tasteful. Looking forward to seeing more pictures. And to think it's all being done in Sweden!
Old Jun 26, 2012 | 09:41 AM
Gordonm's Avatar
Gordonm
Nice project. I am also in the middle of an LS3 swap into my 72. I am using an 09 LS3 and I had the same issue with the PS pulley. I used a pulley from a Ford Van or something like that. Same shaft diameter but the pulley was smaller. It is tight but it fits. I am using a T56 6 speed and hydraulic clutch on mine. Looking forward to more progress on yours.
Old Jun 27, 2012 | 06:09 AM
riggs 74's Avatar
riggs 74
Great build,
Riggs
Old Jun 27, 2012 | 06:30 AM
Garys 68's Avatar
Garys 68
Nice work, keep posting pics.
Old Jun 27, 2012 | 03:43 PM
BB502's Avatar
BB502
I have follow your thread Gordonm wery intresting information in that thread, nice car.
Thank´s everybody for all the comments.
I´m waiting for a call from the firm that has rebuilt the rear axle, so i can put the rear end together.
I also waiting for parts from Ecklers, among other things a stainless steel parking brake kit so i can rebuild my traling arms, i have already set the spindle end play with a set-up tool.
While i wait i´m grinding the underside of the body and the engine compartment so i can paint it in semi gloss black.
Old Jun 27, 2012 | 04:31 PM
jcloving's Avatar
jcloving
Awesome build so far. Your garage is gorgeous too.
Please keep posting pics, it motivates the rest of us.
Old Jun 27, 2012 | 05:11 PM
Rebelrob's Avatar
Rebelrob
Wow... Good job....
And to think you did all this work in 2 days.... simply amazing....
Old Jun 27, 2012 | 06:28 PM
BB502's Avatar
BB502
Originally Posted by Rebelrob
Wow... Good job....
I wish that it was done i two days, then i could perhaps drive the car next week...
but i started in January...
To Project 69-LS3
Old Sep 5, 2012 | 04:36 AM
BB502's Avatar
BB502
It´s time for a small update...
I have received my new wheels, 18" ( front ) with 255/40 tyre and 19" ( rear ) with 275/35 tyre.
I made a bracket for the steeringrack so the steering is now finished.
I will update the thread soon with more pictures.
Old Sep 5, 2012 | 08:21 AM
Sam and Jess's Avatar
Sam and Jess
Great job! What are the wheels you are using? They look really nice.
--Sam
Old Sep 5, 2012 | 08:44 AM
BB502's Avatar
BB502
The wheels is made by company called "Image Wheels",
It´s a cast 3 piece wheel.
