BB502... looks GREAT! I am so envious of your super clean frame!
What kind of body bushings are you using?
Where did you get your bolt kits from?
Thanks,
Ron
I´m using a standard body mount kit for 68-72 (not poly)
I have not bought any bolt kits, all the bolt is the original bolts but i have clean them and had them coated ( a few was to rusty so i bought new ones i my local hardware store )
Originally Posted by Factor
also, (i second) how did you fix the thermostat housing vs suspension issue?
R
I bought a straight thermostat housing on Ebay, it was the easiest solution.
when you lifted the body off the frame...did you just pull the 6 or so body bolts and lift it? or did you disassemble the body to parrtially reassemble it for your lift?
I forgot to show this picture of the new pulley to the steering pump, there is no problem now with the pulley hitting the control arm. ( but i cut the bolt on the control arm , just for safety)
The pulley is a modified pulley from a Saab...
The frame is ready to be reassenbled again.
I made new brake lines:
The engine was painted chevy orange:
The control arms was rebuild with poly bushings:
I purchased a set of Coilovers:
The front end is almost finished:
I´m making my own version of the Steeriod rack and pinion kit ( the steering rack is from a Saab 9-3 ), mounted in brackets i have made:
I haven´t decided if i should go with these brakes (I must use 18" wheels or bigger ) or if i should use standard size brakes so i can use 15" rally wheels if i want to:
The engine is back in the frame again:
I made a bracket on the engineblock so i can use the original clutch likange:
This is so far i have come ( i´m from Sweden so you have to excuse the spelling...)
Your English is a million times better than my Swedish. You're doing fine.
Those brake lines look to be copper. I hope they are not copper. Copper work hardens from vibration, gets brittle and can crack.
Agree with gcusmano about the copper, bad idea. I put SS in for gas and brake lines and the pre-formed lines weren't all that good a fit. Bending them to make them fit was a PITA. After 40+ years my factory steel lines were in pretty good shape so (my two cents) I would recommend you use steel, not stainless steel and not copper.
BB502,
wondering how you got the body off so nicely and together on your lift...
did you just pull the body bolts and lift it?
or did you disassemble the body to partially reassemble it for your lift?
BB502,
thanks,
R
The body was almost empty, i had only the lights in the front, radiator frame and doors mounted.
When i pulled the body i just used my engine hoist, but that hoist do not lift straight up so the body scraped a little against the frame, but i didn´t care at that point.
But when i had the frame finished i didn't want it to be scraped so i had to build another lift.
