700-4R Question
Jul 17, 2012 | 08:04 PM
700-4R Question
I have an '82, 700-4R, the shifter has 3 forward positions (D-3-2). What do I have to do to get the manual 1st so I can have D-3-2-1. A 4 position shifter modification for retro fit 700-4R trans in pre '82s is for sale from several vendors, it seems like a bolt on replacement for the 3 speed auto trans detents. Corvette Central Pt# 533146, kit.
1, Does the '82 700-4R trans manual valve have 4 forward shift positions?
2. Would the 4 position shifter up grade kit fit my '82 OEM shifter since it is used in 77-82 Vetts?
Butch
Jul 17, 2012 | 10:18 PM
I have the conversion shifter in my '79 and it works perfectly. As I understand it, when the General put the 700-R4 in the '82, they didn't bother to change the shifter mechanism. I am pretty sure the conversion shifter will work in your car. You'll probably never need to select first gear, but it only seems to make sense to have a fully functional shifter.
Jul 17, 2012 | 10:36 PM
contact bow tie overdrives they seell shifter conversions
Jul 18, 2012 | 12:14 AM
You can also cut the shifter detent plate down in order to engage first. That's the difference between a 3-speed plate and a 4-speed plate.
Jul 18, 2012 | 09:03 AM
Here's were you grind another detent:
Or you could spend money at BTO, and a few hours swapping the entire shifter...
Jul 18, 2012 | 11:04 AM
Quote:
Originally Posted by
pricesgarage
Which THEY buy from here:
http://www.shiftworks.com/corvette-68-81.htm
Jul 18, 2012 | 12:51 PM
Big2Bird
Hmmm... $275 or grind a notch...I'll grind it for you for $150.
Jul 18, 2012 | 12:53 PM
damoroso
That's all I did to mine. A small hacksaw blade and a file works perfectly. I will caution you !!! Do not slam it in 1st gear while braking! It will lock the rear wheel and get you sideways in a hurry.
Jul 18, 2012 | 01:10 PM
damoroso
The kit is $94.50.
Jul 18, 2012 | 01:11 PM
damoroso
Uhhh, how wide does the notch have to be? I have a Boy Scout pocket knife and a flat file.
Thanks, I believe I'll try that, every, $.01 counts
Butch
Jul 18, 2012 | 01:41 PM
Big2Bird
The kit is $94.50.
Fine, I'll grind the notch for $50. Nearly a 50% savings!!
Jul 18, 2012 | 01:42 PM
bpassmore
Butch
Butch, it just needs to be wide enough and deep enough for the detent to catch. You can determine how hard it catches by who deep you grind it.
damoroso
That include the new bezel? The kit is more than a detent plate.
Jul 18, 2012 | 01:44 PM
damoroso
OK, I GOT $50 WHO'LL GO -$20?
Jul 18, 2012 | 02:17 PM
Big2Bird
Don't need it for an 80-82
Jul 18, 2012 | 02:20 PM
Drive the car out to CA and I'll do it for pizza.
Jul 18, 2012 | 02:24 PM
damoroso
Mine now has OD D 2 L . The original 81 did not.
Jul 18, 2012 | 02:44 PM
I believe I'll try it, Remove the shifter modify the detent, reinstall. The shift cable and adjuster will handle the extra throw?
I have a Pizza now, Who'll go pizza and beer?
Jul 18, 2012 | 04:07 PM
Wow .... I've been wanting to do this as well ...... thx for the tips .....
