Another , will it fit.
Old Aug 6, 2012 | 12:37 PM
scrappy76's Avatar
scrappy76
Default Another , will it fit.
This guy has a hood off a 1971 corvette that goes all the way to the windshield with no wiper door. Is it a direct fit for my 1976 corvette ?
Thanks,
Old Aug 6, 2012 | 02:11 PM
MelWff's Avatar
MelWff
no it is not they changed the curvature I believe after 72. If you look at aftermarket vendors they use different long hoods for a 71 versus a 76
Old Aug 6, 2012 | 03:02 PM
Alan 71's Avatar
Alan 71
Hi s76,
Mel is right.
The question in my mind is was the hood intended (molded) to fit the 71, or did it just end up on the 71?
Knowing what year it was made for, and if it's been modified, may help in knowing whether it'll fit your car.
Regards,
Alan
Old Aug 6, 2012 | 08:32 PM
scrappy76's Avatar
scrappy76
Thanks guys. The seller said it was on his 71 and was getting rid of it because it has holes for hood pins in it. He said since it went all the way to the windshield with no wiper door, it will fit any vette from 68 to 82. Anyways didnt think it would fit but came here to ask all of you guys.
Old Aug 6, 2012 | 08:47 PM
Alan 71's Avatar
Alan 71
Hi S76,
Will Fit. Well yes, more or less.
It's the curve that Mel mentioned that becomes the trouble. The rear upper lip of each fender is different on cars with wiper doors than those later cars without the wiper door.
So the hood needs to be made to fit the fenders, or the fenders needs to be made to fit the hood.
The hood STILL might fit your 76... it depends what it is.
Regards,
Alan
Old Aug 7, 2012 | 12:48 AM
TimAT's Avatar
TimAT
Don't forget- when GM took the wiper door they changed the hood latches too. My 69 has the bullet type and the 77 I had used the hook/loop.
Old Aug 7, 2012 | 08:23 AM
scrappy76's Avatar
scrappy76
I think I am going to pass. I Really didnt need it, but he only wanted $50 for it. I was going to install my L88 scoop on it instead of on the original hood I have.
Old Aug 7, 2012 | 05:02 PM
lvmyvt76's Avatar
lvmyvt76
76 is a one year only hood, you can use a 73-75 with cold air induction if you don't mind the bid hole in it, I did after I could not find a 76 hood, no problem after putting the insulation on the hood.
To Another , will it fit.
