EFI install - air filter question
Old Aug 8, 2012 | 07:39 AM
Belgian1979vette's Avatar
Belgian1979vette
Default EFI install - air filter question
I have a question for those that installed efi on their C3 : where did you install your airfilter. I want it to draw cold air, but the nose of our cars doesn't allow much room for a suitable size air filter.
If you have some pictures, they are greatly appreciated.
Thx
Old Aug 8, 2012 | 08:58 AM
oldalaskaman's Avatar
oldalaskaman
we gotta see pictures of yours to know what you're workin with
Old Aug 8, 2012 | 10:56 AM
mrvette's Avatar
mrvette
Thx
go to my sites below, do some fishing around, and you will see some underhood shots of how I solved the problem....
Old Aug 8, 2012 | 12:53 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
what is the Y from?
Old Aug 8, 2012 | 02:14 PM
Belgian1979vette
Gene, can you still open the hood with that in front of the rad. My hood is not on at the moment, but I remember that space being real tight when the hood was open. I barely had enough room to fit an oil cooler flat to the radiator support.
Old Aug 8, 2012 | 04:40 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
If you look closely, you will see hood pins at the front. It looks like he converted his hood to open the oposite way.
Old Aug 8, 2012 | 05:10 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Yep. He definitely cheated.
Old Aug 8, 2012 | 06:29 PM
Shark Racer's Avatar
Shark Racer
Originally Posted by moonsteel
what is the Y from?
That Y looks like a C5 Corvette filter...
http://www.ecklerscorvette.com/corve...1997-2000.html
Old Aug 8, 2012 | 07:53 PM
oldalaskaman
with his ingenuity,I bet thats a 3" wye fitting
Old Aug 8, 2012 | 07:58 PM
lars's Avatar
lars
Whatever you decide to do, keep in mind that if you end up running an open-element air cleaner that pulls air in from inside the engine compartment, the PCM will retard the timing by 10 degrees or more any time the air inlet temp goes above 140 degrees. This will give you some real tuning and performance problems...
Lars
Old Aug 8, 2012 | 08:01 PM
Shark Racer
Lars
Yep...
...Lars, another question. Would you recommend the stock late C3 air cleaner setup (single or dual snorkel) over an open element?
Old Aug 8, 2012 | 10:57 PM
lars's Avatar
lars
Anything that pulls air in from someplace other than the top of the engine compartment. The late C3 system is actually very good if you can find one complete with all ducts and hardware: This would work well on one of the Holley-style FI setups, but would be difficult to adapt to a C4 TPI forward-facing throttle body.
Lars
Old Aug 8, 2012 | 11:03 PM
Shark Racer
Mine's all intact, although I'm sticking with the single-snorkel for simplicity's sake.
I'm glad I didn't ax it during my young and dumb(er) days...
Old Aug 9, 2012 | 02:59 AM
Belgian1979vette
Lars
Lars,
You're absolutly correct, which is exactly why i'm going for the cold air intake.
I have the ducting system for my 79 which has 2 openings to attach the tubes to. Problem is filtration.
I'm running a crossram stack efi manifold, which makes things a little more complex.
Currently I'm leaning to the setup of the guy in this thread. I would mount a cylindrical K&N filter inside an airbox on top of the stacks (over the valve cover). Hmmm, would only have to figure out how much free room I have from my tall valve covers to the flat surface of the hood.
http://www.turbosport.co.uk/showthre...s-on-twin-48-s
The other option would be to use my filter socks and build an airbox over the intire engine, connecting that to the dual snorkel system.
However it seems that the socks pose a danger with regards to a fire.
Old Aug 9, 2012 | 03:18 AM
oldalaskaman
'cross ram efi' would've been good info at the start of your thread. you could have got better info. look at an 84 C4
Old Aug 9, 2012 | 10:53 AM
Learning_Curve's Avatar
Learning_Curve
I think he's talking about this crossram,
Not "crossfire".
Old Aug 9, 2012 | 10:58 AM
oldalaskaman
aha, excellent point
Old Aug 9, 2012 | 12:52 PM
Belgian1979vette
Not "crossfire".
Comparable, but not completly. Anyway this should give a good idea.
To EFI install - air filter question
