More punch off the line
The engine has never had a rebuild to the best of my knowledge and currently has 59,000 miles (on the odometer). Runs strong, does not smoke or burn any oil. I have not taken it to the redline (maybe 6000 rpm tops) in first gear.
It really bogs off the line when I floor it. My gut is telling me it's the carb, but will look at all possibilities.
First thing you want to do is a good solid baseline setup, which includes verifying the jetting is the correct 68/73 with 6.5/8.5 power valves installed. Also, make sure you have at least an .025 squirter, if not bigger (I'd use a .028 to .032).
Set up your primary/secondary throttle blade openings as outlined in my setup papers: you need both primary and secondary openings at idle to be equal, and you need to verify no more than .020" transition slot exposure on the primary side. Any more than .020 will produce the stumble your describe.
Set your float levels with the engine hot and running. Right to the bottom of the plugs with slight slosh coming out the plugs.
Make sure your accel pump has no slop in it and that the spring loaded rod slightly compresses the accel pump arm at idle for an immediate pump shot with the slightest throttle movement.
Make sure idle mixture screws are equally adjusted and set for best manifold vacuum.
...and make DARNED sure your timing is set right: You should be running about 16 initial with 36 total and a functional vacuum advance hooked up to manifold vacuum in order to produce about 30-32 degrees of timing at idle.
E-mail me if you need the carb setup papers. With things set up as outlined, the car will not stumble, and will smoke the tires by sidestepping the clutch at 2500 rpm. If it doesn't, send me a plane ticket and I'll come set it up for you.
Lars
Ken
Lars
V8FastCars@msn.com
Lars
V8FastCars@msn.com
Lars
V8FastCars@msn.com
Looks to be 3:70 rear end. Found a conversion table that indicated that at 82 mph with this setup I should be turning 3700 RPM. At 41 mph, it should be 1850 rpm.
Here is my results:
41 mph 1900 rpm
60 mph 3000 rpm
82 mph 3700 rpm (approximate, since I didn't want to take my eyes off the road long enoung to confirm exact, but it was over 3500 and less than 4000)
Looks like it's a 3.70 gearing.
"Nervousness" test:
Three attempts to at 3000, 3500, and 4000 rpm. First two, bogged down for a second, then took off, no rubber lost. At 4000, I was able to get a small squeal, but nothing drastic. I'm by no means a mechanic, but from all I have learned here, looks like it is probably a carb problem somewhere.
Ken
Lars
Lars
but i would think you have some binding in the rear end or the some major brake drag, see if your wheel is hot to the touch after a short drive , I had it when I first bought my car one of the brake lines collapse and it wouldnt spin the tires to much. But the falling on its face,
I know you said you checked timing might want to check the firing order 5 and 7 wires can get mixed up easily.
By the way Lars may take you up on that offer for a carb issue have the holley 750 street avenger can remember number but here it is
I had a problem with bog and eventually took it off for a smaller 600 holley and no more problems arose
Lars sent me his carb setup guide. We will be using his settings for timing and carb setup and see what happens. I'll keep you posted.
Ken
Sounds like a 'no-brainer' offer to me....
